Greddy SP2.. Is it Cat-back or Axle-back
Old 03-06-2008, 01:57 AM
ToyoCel's Avatar
Default Greddy SP2.. Is it Cat-back or Axle-back
I just bought the SP2 and it should be arriving in a few days. Every time i read about it on SL though, people say its an axle-back. greddy.com says its a cat-back... SO WHICH ONE IS IT?
ToyoCel is offline
Old 03-06-2008, 01:59 AM
BlckdOutTC's Avatar
axle
BlckdOutTC is offline
Old 03-06-2008, 02:23 AM
ToyoCel's Avatar
This is from www.sportcompactonly.com
Full Stainless Steel Catback Exhaust
Classic GReddy Looks, Sound, & Performance
High Polished Oval Muffler and Tapered Tip
Thick1.2mm Mandrel-Bent Piping
Street-Tuned Straight-Through Design
Emissions Compliant
Sound Tested (under 95dba)
Bolt-on Installation
3yr. Limited Warranty
ToyoCel is offline
Old 03-06-2008, 02:41 AM
ToyoCel's Avatar
Scion tC SP2 Exhaust System - Scion tC Exhaust System
GReddy Exhaust Systems are some of the finest performance exhausts available today. All Scion GReddy exhaust systems (SP2, EVO 2, G2, EVOTT) are complete cat-back exhaust systems unless otherwise stated, which do not effect emissions related hardware. Each specific exhaust system bolts-on, using factory mounting hangers from your tC. GReddy's unique straight-though muffler design gives your tC the perfect compromise between Power, Torque, and a deep, throaty Sound. Although mufflers can look the same from the outside your Scion tC, Greddy's internal construction sets Greddy exhaust systems apart. With countless hours of testing the performance and sound, Greddy's expert Exhaust Technicians tune each application by varying the size or sequence in the perforated tubing and/or changing the amount of non-corrosive stainless-steel mesh and sound-suppressing composite cube packing material within each muffler can. The quality and workmanship extends through the outer shell of the exhaust system. With laser-cut, computerized mandrel bent aluminized tubing, thick flanges, OEM style hangers, and a polished stainless-steel muffler can and exhaust tip, GReddy exhausts look as good as they perform. Each exhaust system type (SP2, EVO 2, G2, EVOTT) varies in the outer look as well as flow characteristic for each application. GReddy's high performance tC exhaust systems are the choice for you. Part # 10117040
SP2 Exhaust System by GReddy for Scion tC
NOW IN FULL STAINLESS STEEL! It wasn't easy to improve on the popular GReddy SP system. But through customer feedback from over 10 years of use and testing, GReddy redesigned the SP as a full stainless steel cat-back exhaust system that is similarly priced to the original GReddy SP system. The new GReddy SP2 features a 304 stainless steel muffler canister with extra strong 430 SS end caps that feature a deep, high polish. Large, high volume mufflers provide maximum flow with a deep, pleasing tone and are especially effective when used on vehicles with aftermarket turbocharger systems. The unique outer curled oval tip (115 x 110mm dia.) is embossed with the famous GReddy logo. Employing state-of-the-art robotic seam welding, the single wall canisters feature increased rigidity for maximum durability and life. With over 35 types of internal perforated tubes, each GReddy SP2 exhaust application is specifically tuned for the best combination of sound and performance. The new GReddy SP2 also features thick walled (1.5mm), polished 304 stainless steel mandrel bent piping for better resonance and vibration control and enhanced corrosion resistance and durability. New lightweight, flared and stamped stainless steel flanges are also used to provide improved sealing characteristics. The GReddy SP2 Exhaust System will initially be available for over 50 popular Japanese vehicles with more to come as they are developed.
ToyoCel is offline
BlckdOutTC's Avatar
Greddy SP2 Axleback Exhaust System- customcarcentral.com
Greddy SP2 Rear Section For Scion TC #16724 - killetrc
only includes 2 pipes cannot be a catback
robtheqb2003's Avatar
I have it and its an axleback...
robtheqb2003 is offline
Old 03-06-2008, 02:52 AM
ToyoCel's Avatar
Wow... This is amazing. I find it odd though that most websites advertise it as a cat-back when in fact its an axle-back. Why would they do that? Couldn't they get sued for misleading people?
ToyoCel is offline
BuddhasTC's Avatar
http://www.greddy.com/products/displ...&SubCategory=1
this is from the Greddy website...the general SP2 muffler is a catback, but if you look on the list near the bottom, for some, including the tC's...is a rear section only = axleback
BuddhasTC is offline
Old 03-06-2008, 02:56 AM
BlckdOutTC's Avatar
^^yuppp
Old 03-06-2008, 02:57 AM
davedavetC's Avatar
yea, generaly the exhaust is a cat back but we got screwed and got an axleback that is over priced
davedavetC is offline
Old 03-06-2008, 02:59 AM
ToyoCel's Avatar
I am very dissapointed right now. I was hoping to have this installed by the 14th. Damn this sucks. Im going to have to cancel my order. I didn't like th idea of a 2.364" piping anyways.... I'm about to by Megan instead w the downpipe!!!!
ToyoCel is offline
Old 03-06-2008, 03:00 AM
BlckdOutTC's Avatar
yeah thats happened quite often on our cars hasnt it lol
Old 03-08-2008, 09:48 PM
ToyoCel's Avatar
ok guys heres whats up. This info took me 2 days to gather so I hope its helpful to people out there looking for the right exhaust for their car.
The 2nd exhaust in our cars are located towards the rear of our cars. That is why almost all exhausts for our cars are axle-backs.... but since it from the cat back, its also considered a cat-back exhaust. So to recap; axle-back = cat-back. Samething for our cars. hope this helps.
ToyoCel is offline
Old 03-08-2008, 10:28 PM
op07tc's Avatar
stupid greddy...........
op07tc is offline
Old 03-09-2008, 11:25 PM
BlckdOutTC's Avatar
cat back includes mid pipe where the cat is. starts at the cat and goes all the way back
axle back starts at the rear axle and does back, no mid pipe, no cat
I have megan drift spec CATback and megan s pipe and love it
tckid21
01-09-2016 09:19 PM
CrowJenkins
10-09-2015 10:47 PM
vi3tb0i09
09-23-2015 08:32 PM
carid
08-31-2015 11:17 AM
Quick Reply: Greddy SP2.. Is it Cat-back or Axle-back
