2AZ Engine Assembly
Old 05-30-2011, 06:20 AM
trd07tc's Avatar
no my headstuds are just 75ft lbs. the rod bolts were 25 ft lbs then 55 degrees as per K1 (Carillo).
trd07tc is offline
Old 05-30-2011, 06:42 AM
crush02342002's Avatar
word...go with what arp says...I will say i was able to go 80ftlbs on marcials headstuds without any issues. just saying you have some leway but stick to what arp recommends.
crush02342002 is offline
Old 05-30-2011, 01:03 PM
Ronin Scion
Ace83's Avatar
cool just as i thought, just wanna be sure im good skipping that extra 90 degree step on the manual
Ace83 is offline
Old 06-07-2011, 06:57 PM
RSracer's Avatar
Wow, no measurement were taken at all in this? No machining or cylinder honing? You didn't even get the block wash? Balance shaft delete without getting the rotationg assembly balanced. Man, why do people cut corners on engine work, an expensive way to learn a lesson. Don't tell me you are going to run an emange blue with it? Good Luck.
RSracer is offline
Old 06-07-2011, 07:22 PM
Ronin Scion
Ace83's Avatar
im pretty sure he did necessary measurements.. but looks like he just showed all about engine assembly not the entire engine build.. its a guide not a step by step DIY for dummies
Ace83 is offline
Old 06-07-2011, 07:46 PM
trd07tc's Avatar
I used a ruler.
trd07tc is offline
Old 01-06-2012, 09:54 AM
tc_turbocoupe's Avatar
any possible way i can get this same manifold made? Im doing a very similar build!!! very!!
tc_turbocoupe is offline
Old 03-16-2012, 07:29 PM
trd07tc's Avatar
How many people have actually used this?
trd07tc is offline
Old 03-22-2012, 05:17 PM
stocksciontc's Avatar
Not sure, but its a great read. Thanks a lot for posting it.
stocksciontc is offline
Old 03-22-2012, 09:02 PM
Syldrin's Avatar
i planned on using it mike why do you ask? i just got caught up changing turbo kits instead building my block.
Syldrin is offline
Old 03-24-2012, 09:17 PM
trd07tc's Avatar
Just curious.
trd07tc is offline
Old 09-17-2012, 05:37 PM
R3define's Avatar
Thanks for this write up. Will be much easier to put my engine back together.
R3define is offline
Old 11-27-2012, 10:02 PM
Music City Scions
BlackKnight's Avatar
Great write up! Did you plasti gauge the bearings to insure proper clearance?
Sent from my SGH-T999 using Tapatalk 2
BlackKnight is offline
Old 12-18-2012, 04:48 PM
SoccerBoy_AP's Avatar
I hope to one day have the time and space to do teardown and rebuld of my engine, this will be my manual. Great work/DIY!!
SoccerBoy_AP is offline
Old 12-20-2012, 03:35 AM
Awsgoskate's Avatar
Default buying a 2azfe?
wanting to buy a tc engine/ 2azfe motor so that I can take it apart and build. I only want to buy one if its cheap, if it burns oil thats oil etc, thats ok. I just want a cheap one that is worth rebuilding. to learn on and maybe use.. anyone know of any cheapos?
Awsgoskate is offline
Old 07-05-2013, 06:28 PM
bubblehead24's Avatar
Default Cam caps
My mechanic did some work on the Heads, when he put the Cam Caps back on, is there a specific order that they have to go in.
bubblehead24 is offline
Old 07-24-2013, 04:38 AM
EvoAKCYABYE's Avatar
Great write up. Awesome build. Never got the chance to do mine before I sold it so it was nice seeing the build process on this motor.
EvoAKCYABYE is offline
Old 07-31-2013, 03:05 PM
After 90k miles (50K of them with a S/C) I've started noticing a metalic tick while at idle/low rpm. I'm guessing that something is now out of alignment or breaking/broken.
Thankfully I recentlly acquired my new DailyDriver (95' Subaru Legacy Outback) so I can put the tC up on blocks and start tearing the engine apart. While I'm in there looking for the problem I'll be doing some serious overhaul and maybe some part swapping to handle the higher HP, since the stock 2ZA-FE doesn't do well past ~250hp.
Might start my own thread on the work, but it won't be done any time soon. I'll be using whatever time I can find.
While the S/C is removed, I'll be doing a rebuild on it too!
Old 09-10-2013, 02:59 AM
trd07tc's Avatar
Planning to update this with part numbers and a torque spec/clearance reference sheet.
trd07tc is offline
Old 09-10-2013, 03:00 AM
trd07tc's Avatar
They are numbered.
trd07tc is offline
Quick Reply: 2AZ Engine Assembly
