Boosted engine runs poorly after warmed up
Old 10-23-2014, 03:46 PM
darkshadowofxdeath's Avatar
Default Boosted engine runs poorly after warmed up
Title sums it up, according to my wideband I'm running at about a 14.7 af ration before the engine warms up, car runs nice until it heats up then my af is like 15 or 16 at idle after it's up to temperature. I bought this car with the turbo setup already installed and it looks like someone swapped an engine out, I'm thinking maybe someone didn't step down the spark plugs when they swapped? Running aftermarket injectors (Not sure of the cc's but they are orange if that helps), Intercooled Turbo, AEM FIC, Wideband 02, No CEL, anywho any help would be appreciated! Running about 6-8psi, Tian Wastegate, hks BOV.
darkshadowofxdeath is offline
Old 10-27-2014, 11:45 PM
That_Kid_Ju's Avatar
Might help to have someone check the tune. Plugs and injectors could also be suspect. It's always sketchy buying a car that is already boosted cuz you don't know exactly what's in it, what's been done, and how well it was done.
That_Kid_Ju is offline
Old 10-28-2014, 03:15 AM
GUNNIST14's Avatar
like kid ju said you need to have tune checked by a professional that has experience with TC's and aem fic. Where are you located?
GUNNIST14 is offline
Old 10-28-2014, 06:57 PM
Took a closer look at the car, it's running stock injectors, the motor has been swapped, and somewhat recently I think. A big part of the problem was a boost leak which I sealed up although now I think I have another one. I was thinking whoever swapped the motor didn't think to step down the spark plugs, I hit up dezod and they confirmed it was one of their earlier turbo kits. I live in Peoria, IL. Here is the engine http://imgur.com/L4IHtb2,6oNRdc3 Everything seems to be well done, the FIC was nicely hidden the gauges were installed nicely, exhaust and suspension seem to all be in order. I'd like to check a few things before I resort to a tuning shop, My thoughts are the following: It was a junkyard motor so I'm thinking I should check the spark plugs and see if they need to be a step or two colder, if this is the case running a dezod at 8psi how low should I go in that regard. Next step is to spend some time finding that boost leak if there still is one, I noticed the BOV can be turned by hand so I'm thinking that may be a part of the leak issue. Any thing else after that I should try? I want the tuning place to be a last resort as it's the most expensive.
Old 10-28-2014, 07:27 PM
And I should add on a hard pull it's gotten down to 10 or 11 on the a/f gauge
GUNNIST14's Avatar
The plugs won't cause the engine to go lean after warm up unless there really hot plugs but the previous owner should've known you go 1 step colder when going turbo. A boost leak will contribute it as more air being added to the motor and not enough fuel to compensate. Make sure the wideband is functioning correctly. Remove the wideband from the downpipe and spray brake clean on and watch the gauge.
Old 10-28-2014, 07:30 PM
GUNNIST14's Avatar
The wideband should go fully rich and stay there until all the brake clean has evaporated and the wideband can't smell the chemical... if the wideband goes lean with brake clean applied to it the sensor is not good.. sorry if i miss some words I'm on my cell...
Old 10-28-2014, 07:33 PM
GUNNIST14's Avatar
P.s. the the wideband will stay rich for a day if you spray it with brake clean as the bosch sensor is super sensitive so don't drench the sensor just a few lights sprays should work...
Old 10-28-2014, 07:35 PM
GUNNIST14's Avatar
Your fuel injectors are also a possible culprit if one is blocked or the spray pattern is incorrect that could be your problem...
Old 10-29-2014, 06:41 PM
Checked the spark plugs, they are the stock ones, do I need to go one or two steps colder for 8psi?
Old 10-29-2014, 06:50 PM
hata's Avatar
you can go one or two step colder spark plugs but they do need to be changed due to F/I. Either way will not hurt.
hata is offline
Old 10-29-2014, 06:59 PM
which one will be safer for the engine?
Old 10-29-2014, 07:03 PM
hata's Avatar
both. One step or two step colder is safe for the engine. If the one step NGK's are not available, buy the two step.
hata is offline
Old 10-29-2014, 07:14 PM
Do I need to change the gap at all?
Old 10-29-2014, 07:20 PM
GUNNIST14's Avatar
Darkfox hata makes a good point but 2 step colder plugs will be too low for only 8psi. 1-step colder should be optimal for 8 psi. If you buy the IRIDIUM NGK BkR7-11 NGK recommends not to gap them but at the same time the gap might be too large for low boost settings..
Old 10-29-2014, 07:21 PM
GUNNIST14's Avatar
When I get home I'll post the NGK plugs you should get.
Old 10-29-2014, 07:22 PM
GUNNIST14's Avatar
Any progress in finding out why your leaning out idle.
Old 10-29-2014, 07:23 PM
Yeah those are the plugs I ordered
Old 10-29-2014, 07:24 PM
I think a big part of the lean idle had to do with a boost leak, there was a line that connected to the fic that i could hear so I went ahead and patched that up, I just got the snap ring in for the BOV and I'm hoping that takes care of the other big leak, cause I'm pretty sure I shouldn't be able to easily turn the bov by hand
Old 10-29-2014, 07:25 PM
GUNNIST14's Avatar
Well check the gap I think they will be at 44 which might be too high.
Quick Reply: Boosted engine runs poorly after warmed up
