EGT (Exhaust Gas Temp) before turbo installation
Originally Posted by TurboCustomz
Scion Dads car runs rotary EGT's
No seriously, I would have some concern if I ever saw 1500 degree's under load. Or anytime for that matter on a piston engine.
Yeah I'd take a look at it. But it could just be a faulty sensor. My Evo ran pretty hot at 23psi, but I had around those temps where the EGT was tapped into the manifold, not the S-pipe. S-pipe readings shouldn't be up that high,
Well, last night I looked at the probe and I think I found the problem because it reads different. When I installed the probe, I pushed it all the way. I read the instructions and it said 2/3 of the way in. I redid it and ran the car.
Idle was between 600 and 700 (650 in gear)
normal driving between 1050 and 1250 and 1400 was the max as I ran it wot.....on our special test track.
Originally Posted by cdubber9
See it's not so bad to read the instructions, I always get made fun of for it, but I do it anyways.
Those numbers look way better.
*LOL* instructions..? What are instructions? I guess I should have read mine hahaha. I stuck her about 90% in and was reading the exact same temps as you. Had me super worried last night!
I'm on my second probe already. First one got taken out by a curb......Ooops. But if you ever need a replacement, check out ebay. I got one for $35.00, sure beats the $185.00 it cost for a Defi replacement. They don't last forever, all it is standard thermocouple which will burn out after time, so don't waste money on the gauge brand replacement.
On my turbo Z and granted this reading is at the feed pipe for the turbo I run:
400-600 idle
800-1000 cruise
1000-1200 WOT
1150-1350 Road Race
400-600 idle
800-1000 cruise
1000-1200 WOT
1150-1350 Road Race
Man I am still having really high egt problems... If I put the car in cruise at 75-80mph I peg the egt to 1600. I cannot figure this out. It has to be the gauge or thermocouple. Spark plugs show no sign of this kind of heat, engine runs perfect, no signs of detonation, no check engine lights etc... This is totally wacko. Any idea's..?
Sorry to resurrect an old thread, but I'm about to poo bricks, right now.
I might have stuck the probe in too deep, like the OP had done, but still ...
I have no clue what recommended EGT's I should be watching for.
I only installed the gauges after I put in the turbo, so
I have no frame of reference. So far, at idle,
I get 800 F, give or take 250 degrees.
Cruising at 45, I get around maybe 1,000 F.
Cruising on the freeway @ 80, I get 1,200-1,300, and
at WOT, the thing is pegged at 1,500.
I know I shouldn't let it get to 1,500, and I usually don't.
I just don't know what's going on with my engine.
I read the instructions online HERE.
It doesn't say anything about how far to put the probe in.
I tapped directly next to cylinder 4.
It seemed to be the easiest spot to run wires since its near the
oil pressure and o2 sensor harnesses.
Oh !!! And since my gauge only goes up to 1,500 degress,
there's no way to tell if I'm reaching "piston frying temperatures"
HELP !!!
HELP !!!
hampton1100
05-28-2015 07:32 AM
TheTripleC
01-04-2015 06:46 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
TheRedBox
31
12-02-2003 04:53 PM
