Help with a map please
Put a turbo on my 09 Toyota Matrix and have it running with the FIC bypassed. Can't find any turbo toyota forums or info so I was hoping someone here could help me here. 2AZ motor, 550 injectors, high flow fuel with regulator set at 43 and a return line, 2 1/2" exhaust. I made a new fuel map by entering the 2 injector sizes 332/550 and the numbers look o.k. Just trying to get it running on the FIC to to drive to my tuner (73 miles). Thanks
pkinsel@roadrunner.com
Hit up Dezod. They may be able to help you out. Leave the O2 and Ignition maps zero'd out. You'll need a scan tool to adjust the fuel map. Maf map is a bit trickier, but Dezod has a great how to for idle. You can probably expand from that to set up a somewhat decent maf clamp.
I've decided to go ahead and build my own maps. Done everything else so far so why not. Already got a good start on the fuel map. Maf map tomorrow and then the real work begins. Should I do the Ignition eventually?
