Tapping for BOV
Tapping for BOV
Hello everyone, recently turboed the xB. Running a descendent kit with a Tial-Q. I'm not recirculating, I'm venting to atmosphere. I have my BOV tapped into the Vibrant vacuum block and it's not blowing off, it needs a main vacuum source. So my question is where did you guys tap to get the main source when venting to atmosphere.
P.S. I removed the air box and rain a pipe from the IC to the TB.
It's fluttering or flat out not blowing off at all? Do you have a boost gauge hooked up to the vac block? If everything is working read your vacuum and make sure you have the tial spring that matches that vac number. What sounds are you hearing when you boost & let off? If you absolutely don't hear a thing then you could be boost leaking all of the produced boost before it builds the pressure at the throttle body and bov location? Go on YouTube and listen to videos of cars without blow off valves. The air has to go somewhere so if the bov is in fact not opening of hooked up the car would sound like this.
Where is your vacuum source for the block? You should be using the brake booster which should be a very strong source since it needs to assist in braking force. Also, check your springs on the bov. I see that some people have issues with too stiff of a spring with that bov.
Strange. You can certainly try a dedicated vac source, but that one really should be pretty good. You can also try a slightly weaker spring, provided that it stays closed at idle.
I'm not familiar with this particular bov. Is there a preload adjustment?
SloTC1
08-16-2018 02:45 PM
Hydryman
02-23-2016 03:35 PM
ScionLife Editor
09-15-2015 04:40 AM
