* tC : HVAC / Climate Control LED Conversion Guide
#101
I'm wanting to swap out my LEDs with blue and white but i wanted to know if there are any specific blue and white LEDs I should buy. And if I'm doing that i was curious as to where to get the resistors and voltage regulator.
Thanks
Thanks
#102
http://store.ledmod.com/index.php?ma...products_id=15
http://store.ledmod.com/index.php?ma...products_id=12
#106
I've done 2 HVAC led swaps and am working on my third. This one seems to have more dim defrost, a/c and circulation button lights.
Any advice on what resistor or resistors or anything else that could cause this?
Please and thank you
#107
Did you swap out the resistor already??
#108
#109
Check your soldering and also see if you didn't fried the LED (swap out with another new LED)
#111
I was able to do this swap a couple weeks ago along with the gauge cluster which i wouldnt have been able to do without these guides, they are great! However, during the drive back to school, the LCD screen on the HVAC flickers between fully bright, roughly half, and then cut to not having any back light what so ever and now does this every once in awhile since. The screen and everything works and is not broken so could this be caused by the resistor to the LCD having a bad connection? or one of the three LEDs? Everything else works except the back light.
#112
I actually have the same issue on one of my lights for my speedometer.
Just haven't had the time to take it back apart to either resolder/replace the LED that's doing it.
_____
#113
In regards to the install images....are they all duplicates images or are they for different HVAC units?
I just see the years...sorry for the dumb question.
Needing a install sheet for a 2010 Scion tC HVAC switch and all the images are confusing.
____
____
#114
Looks like there are a few duplicate images, but just pay attention to the model years. I did this mod twice and it wasn't that bad at all.
#115
Thanks for the info..... I've done chevy silverado led conversions. Someone just asked me about a 2010 scion HVAC switch..... just needed to know the resistor/LED locations.
#118
Check out MengMotorsports.com, they provide LED parts and LED swap services!
Meng Motorsports LED Swap Scion tC 05-10 - Meng Motorsports
____
____
#119
Hey guys just wanted to share some extra info on this LED Conversion guide. I made a Youtube video on this a while back, just thought I would share this to help out!
Check out the video -
Other Helpful Scion TC Videos can be found here -
Youtube.com/VinnieT8
Hope this helps!
Hope this helps!
LEDmod
Scion tC 1G ICE & Interior
265
11-17-2023 04:54 PM
LEDmod
39
02-12-2013 02:22 AM
O5_TRD_tC
Regional - Pacific Mid
123
06-11-2009 04:15 AM
