* tC : HVAC / Climate Control LED Conversion Guide
Old 06-24-2007, 09:08 PM
LEDmod's Avatar
Default * tC : HVAC / Climate Control LED Conversion Guide
Scion tC : HVAC / Climate Control LED Conversion/Swap Guide
by www.LEDmod.com
** NOTE : This isn't for beginner, so if you aren't sure you can do this then, please seek professional help.
I also offer installation for Local and Out of state customers
Local installation service available below (Follow the link for more information)
- Southern California
- Las Vegas
- New York (Currently not available)
- For out of state customers, please e-mail me for information Sean@LEDmod.com
Here is a step by step guide for LED Conversion/Swap
Things you'll need (Mostly available at RadioShack)
- Fine point Pencil Soldering Iron (Recommend 15-30 watt)
- Solder : Prefer silver-bearing solder or rosin core solder (Thinner the better, easier to work with)
- Soldering accesories
- Philips screw driver
- 10mm socket wrench or needle plier
- Surface mount LED, resistor and voltage regulator (Available at LEDmod.com)
*** NOTE : If you are doing Red LED conversion, you can skip the resistor and voltage regulator swap.
Just change all the LED to RED, also removing the LCD screen is a must
Result will be similar to this (link by SquallLHeart)
LEDmod is offline
Old 06-25-2007, 01:05 AM
Hyghgynx's Avatar
Schweeet!!
Hyghgynx is offline
Old 06-25-2007, 01:29 AM
Daskid's Avatar
Impressive!!!
Daskid is offline
Old 06-25-2007, 02:30 AM
magnetic's Avatar
Nice! Looks a lot easier than I once thought. It kinda eases my mind knowing that those PLCCs are lot bigger than the 0603 LEDs like in the Wiimotes.
I know that SL has a tech article for the gauge cluster already, but I'd like to see a guide like this one for the gauge cluster.
magnetic is offline
Old 06-25-2007, 03:05 AM
LEDmod's Avatar
I'll be making one for the gauge cluster soon....
After I'm done with the 07 and up model for climate control..
I have all the pictures, but need to spend time making them all nice and easy to understand....
LEDmod is offline
Old 07-04-2007, 04:48 AM
magnetic's Avatar
So I got a quick question: I tentatively want my HVAC to be all white, with the on/off lights be red. Will doing the resistor swap harm those red LEDs in any way?
magnetic is offline
Old 07-04-2007, 04:49 PM
LEDmod's Avatar
For the on/off LED, resistor mod won't effect them...
LEDmod is offline
Old 07-05-2007, 10:42 PM
ScottTc13's Avatar
Excellent write up! Very professional.
Be careful removing the lcd. =) I cracked mine =( It's been broken for a very long time now. If anyone has a replacement, I'll buy it. Seriously.
ScottTc13 is offline
Old 09-06-2007, 09:33 PM
LEDmod's Avatar
Guide has been updated with 07+ Models
LEDmod is offline
Old 09-13-2007, 04:33 PM
Guanato's Avatar
are the resistors plug and play or needs desolder and solder too?
Guanato is offline
Old 09-13-2007, 06:49 PM
LEDmod's Avatar
You'll need to install them by using soldering iron..
LEDmod is offline
Old 09-13-2007, 07:07 PM
frankryzzo's Avatar
When doing the LCD screen, how do you get the Reverse look to it?
Does that require a different screen, or do you just put it in backwards?
__________________
frankryzzo is offline
Old 09-14-2007, 01:44 AM
LEDmod's Avatar
Originally Posted by frankryzzo
When doing the lcd screen, how do you get the revers look to it? Does that require a different screen, or do you just put it in backwards?
There is two way to do the reverse LCD..
Reversing the stock film and using new film that will reverse it(I sell them)
If you use the stock film, it's really hard to keep it clean. Since it's tidious to remove the film without bending and remove the adhesive...
When using new film, just clean up the adhesive after removing the stock film...
It's easy to remove the adhesive on the LCD screen it self... just apply some adhesive remover and scrape it off with sharp razor blade.....
Then put new film, it comes with self adhesive layer...
LEDmod is offline
Old 11-25-2007, 06:30 AM
PhantomGT's Avatar
Is there a way to change the CD Player/ Head unit LCD to another color?
PhantomGT is offline
Old 11-25-2007, 08:50 AM
SquallLHeart's Avatar
yes.
SquallLHeart is offline
Old 11-25-2007, 11:06 PM
LEDmod's Avatar
I'll probably make another guide on stock Radio LED conversion guide....
LEDmod is offline
Old 05-05-2008, 03:35 AM
OhioScions
jsingh's Avatar
i really want this set up...but can't do it by myself!!
jsingh is offline
Old 05-05-2008, 05:31 AM
Garage1217's Avatar
I highly recommend NOT useing solder braid, it is how 95% of the first time swappers crack their screens. Use a solder sucker and do it right. Also a writup on resistor placement & info has been up for 2 years now Pretty hard to make wheel more... round
Last, the power ic you are useing is only a 500ma unit, should be a 1amp rated unit minimum.
Garage1217 is offline
Old 05-05-2008, 05:36 AM
O5_TRD_tC's Avatar
yep, u dont want the solder to drip down.
O5_TRD_tC is offline
Old 05-05-2008, 07:00 AM
Garage1217's Avatar
Noobs also put to much heat on the braid for far to long which damages the lcd screens. All around a long painfully annoying process to use solder braid which usually results in some sort of damage. I can desolder a screen in around 1 - 1.5 minutes with the equipment I have and I am not even in a hurry And non techies can do the same in a little more time with just a solder sucker & low wattage iron.
Quick Reply: * tC : HVAC / Climate Control LED Conversion Guide
