2010 stock sub remote wire
Old 07-06-2010, 07:31 PM
hi10tc's Avatar
Question 2010 stock sub remote wire
So, I installed my amp and 2 10's the other day and the wire I hooked into for remote is a bigger yellow wire that is part of the 2010 tC stock sub harness. I noticed that with this wire hooked in as remote the fan on the amp stays on all the time even with the key out of the ignition, So I guess what I have to do is figure out what other wire I can use because with remote being hooked to the yellow wire my passenger window and sunroof do not work either, Any ideas on how to fix these little problems....??
p.s. I already tried using the small blue wire for remote...?
hi10tc is offline
Old 07-06-2010, 10:51 PM
hi10tc's Avatar
28 views and no reply?? I know I saw a post about this same thing a couple days ago I just can't find it now. It listed 3 options for where to hook the remote wire-
Help??
hi10tc is offline
Old 07-06-2010, 11:35 PM
AcidDrop's Avatar
you tried using the small blue wire from the stock sub wiring harness or from behind the radio?
AcidDrop is offline
Old 07-06-2010, 11:57 PM
hi10tc's Avatar
Yeah, and it didn't work, I can try swapping it again maybe idk? Its just a little tiny royal blue wire. maybe if I start my car after I rehook it to the blue one, just realized I didn't start my car the first time.... might have been the problem...
Now i guess my question is if ^^ that is my problem do you think when I unsplice out of the yellow wire it will restore power to my window and sunroof??
Acid- I used the small blue wire out from the stock sub harness
hi10tc is offline
Old 07-07-2010, 01:02 AM
DJ08tC's Avatar
take a volt meter and check the pinouts on the back of the headunit until you find one that is 12 volts when the key is on accessories or on.
The passenger side window and sunroof need to be reset because you probably discounted the battery. Just go of the the passenger side window roll it down some and then roll it up and hold the button for a few seconds. do the same with the sunroof. its in the owners manual.
DJ08tC is offline
Old 07-07-2010, 03:46 AM
AcidDrop's Avatar
just use the blue wire from behind the headunit which is probably your best bet, i don't have an 08 but also the ones i've installed amps/subs for i just use the wire from behind the headunit which is easier for me.
AcidDrop is offline
Old 07-07-2010, 09:47 AM
hi10tc's Avatar
Ok- anyone know if I can use any of the wires coming off the little stock amp so I don't have to run a remote all the way to the HU?? If not it's cool, I'd rather be safe than sorry
hi10tc is offline
wwotr
03-28-2015 01:47 AM
BV19869
12-11-2014 06:05 PM
darkshadowofxdeath
12-03-2014 06:59 PM
umnitza
12-01-2014 06:26 PM
supaguy
23
04-10-2008 08:29 PM
Quick Reply: 2010 stock sub remote wire
