Remote Start Install/ Push Button Start..
Okay short and sweet; I am pre-wiring my remote start 5701. On the PKALL unit what does the blue/white wire (-) when run status connect to, and do I need to connect
the H2 OEM arm OEM disarm to the lock unlock? H3 harness, where do the wires connect in the car? Do I used the smaller relay out (remote starter output) harness instead?
H3 harness: (guessing) DOWNLOAD LINK
Pink IGN 1 (+) output - also ignition sense input (Yellow IG1 4)
Red/white fused 30a (no f'n clue)
Orange Acessory (Grey ACC 3)
Violet Starter - output car side of starter wire (no clue)
Green Starter - input key side of starter wire (no clue)
Red 12v constant - fused 30a input for ign 1 relay (what)
Pink/ white flex relay - output default is ignition 2
Pink/ black flex relay contact 87a - default is ignition 2
Red/ black fused 30a - for accessory and starter relay
Second part
I am doing a push button to start and want to remove the key turn completely.
Would this require 4 relays for IG1 IG2 ST1 ST2 or should I just remove the IG wires and put them to relays and switch?
__________________
Second part
__________________
You do not need that harness unless your tC comes with a factory security system. This harness enables you to have the aftermarket remote start unit to work together with the factory alarm system.
http://www.bulldogsecurity.com/bdnew...ngdiagrams.asp
[/quote]
gan777
18
05-14-2009 04:19 AM
nonstopbost
33
11-07-2007 06:06 PM
