Headlight problem (blown fuses) - Scionlife.com
Reply
Thread Tools Search this Thread
Old 04-07-2007, 11:51 PM   #1
Phanon_TC's Avatar
Default Headlight problem (blown fuses)
Just yesterday my passenger side headlight (stock with silverstar) wouldn't turn on. At first I thought the bulb was shoot but was in perfect condition. I checked the fuse and it was blown so I replaced it. Immediately after turning my car on, the fuse blew out. I have gone through 4 fuses of the same amp and blows out immediately. Anything I could be looking for that would cause this? I hate driving with just one headlight on
Phanon_TC is offline   Reply With Quote
Old 04-08-2007, 01:29 AM   #2
This happen right after you put those bulbs on?
tonytc05 is offline   Reply With Quote
Old 04-08-2007, 01:52 AM   #3
Phanon_TC's Avatar
i've had the bulbs in there for more than more than 5 months. I haven't done anything on my car except for change the oil and rotate the tires about 3 days ago. the headlights were working for a day afterwards... my drivers side light still works just fine
gonna try and get a multimeter tomorrow but even then, not sure how it'll help if i do find out if its feeding too much power.
Old 04-08-2007, 04:45 AM   #4
take it back to the dealer
aznvthugforlife is offline   Reply With Quote
Old 04-08-2007, 08:10 AM   #5
Hyghgynx's Avatar
Check your harness? Some aftermarket bulbs burn the OEM harnesses. (Usually due to the high wattage they draw.) Kind of weird though because I've had SilverStars in my headlights for over a year now with no problems.
Hyghgynx is offline   Reply With Quote
Old 04-08-2007, 08:12 AM   #6
SilyOtter's Avatar
.. swap the bulbs left to right. see if it blows the other fuse.. im pretty sure the tc has one fuse for the left one for the right.. and if hte case.. bulb is shorted internally.. if not take it to the dealer..
SilyOtter is offline   Reply With Quote
Old 04-08-2007, 09:35 AM   #7
CarbonXe's Avatar
You probably burnt up the stock harness by putting those bulbs in, causing the power to short to ground, which results in a blown fuse.
CarbonXe is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
05xB gauge cluster, HVAC cluster, tail running lights, and headlight chime dont work missing_image Scion xA/xB 1st-Gen ICE & Interior 2 02-07-2015 08:18 PM
Battery Drain from Radio Fuse EvalEvan66 Scion tC 1G Drivetrain & Power 7 01-27-2015 03:26 AM
Fuse for climate control and trac control lights Green_rino Scion FR-S ICE & Interior 1 01-20-2015 02:41 AM
Battery Drain from Radio Fuse EvalEvan66 Scion tC 1G Owners Lounge 1 01-16-2015 09:34 PM
Dashboard lighting not working when headlights on LeChuck Scion xB 2nd-Gen Owners Lounge 2 12-09-2014 03:26 AM
Tags
2005, 2006, blowing, blown, fuse, fuses, headlight, headlights, passenger, problem, scion, short, tc, working, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
