OEM Subwoofer Wiring (under trunk floor)
Old 12-09-2011, 11:19 AM
theresanothertc's Avatar
Default OEM Subwoofer Wiring (under trunk floor)
Thought I'd post the wire colors for the 6" under trunk floor OEM subwoofer. I have mine installed in an 06. It sounds great but it uses high level inputs for the signal and there's no built in crossover. It combines the Left and Right signals so be sure to hook both up, otherwise you only get half the output from the sub. I'm surprised because this enclosure is ported and it's a 2 ohm woofer. It sounded better than i thought.
Left (+) Pink
Left (-) Purple
Right (+) Green
Right (-) Blue
Ground - White W/Black Stripe
12V - Blue
Turn on - White
theresanothertc is offline
Old 12-09-2011, 02:42 PM
DigitalPro's Avatar
It's really not bad, try wrapping it with 2 layers of dynamat for even more output. Since it's just a plastic shell it really loses it's kick, make sure it's mounted securely to reduce vibrations even more.
DigitalPro is offline
Old 09-17-2014, 06:55 PM
tCjosh's Avatar
I also got an 06 and want this sub in my tc, so you just have to splice those wires to the existing speaker wires that are in the car to get this sub to work?
tCjosh is offline
herwig
Scion tC 1G ICE & Interior
03-23-2015 04:19 AM
mischadoll
03-09-2015 05:48 AM
mischman
01-14-2015 06:07 PM
toyotaisme
01-10-2015 10:24 PM
randomsuper
12-16-2014 09:11 PM
Quick Reply: OEM Subwoofer Wiring (under trunk floor)
