Passenger Window and Moon Roof Won't Open
Old 12-02-2014, 05:50 PM
pier0723's Avatar
Default Passenger Window and Moon Roof Won't Open
I recently had a get a new battery for my '06 TC. Afterward, passenger window and moon roof won't open anymore. I've done my research, read the owner's manual.. all said to roll windows half down.. the problem is, I CAN'T ROLL THE WINDOW DOWN. No, the lock button wasn't locked. I remembered reading somewhere a long time ago that while testing the window, my key should be in some sort of position. I had the key in ACC, and also in ON.. no matter how long I held the window switch up (on either side of the seat), the passenger window just wouldn't move..
Anyone else have any brilliant suggestion? My last resort is to take it back to my mechanic, but it's heavy raining right now.. Thanks in advance!!
pier0723 is offline
Old 12-03-2014, 02:29 PM
Nicolewelker22's Avatar
I've had this happen after replacing my battery... You'll probably need two people... Your window button should be blinking or something of that sort, your passenger Window will not roll down from drivers side, that is because you lost your battery connection, and you need to reset It; you'll need to turn the car on then back off, switch the key to acc/on (do not start the car) Have someone on the drivers side and a person on the passenger side, roll both the windows down(at the same time) all the way down then back up, hold the button for a couple seconds after the windows have closed, the moonroof is done the same you open the roof then close it, you keep holding that button for 3-4 seconds after it has closed. The hatch is reset by simply unlocking and locking from your master key. Sorry if that was confusing.. Lol
Nicolewelker22 is offline
Old 12-03-2014, 03:38 PM
Basebllstar's Avatar
Something like that. ^^ One person will do the trick. Just roll the window down and then up again holding the switch after it closes until it relearns the position. Same procedure for the Moon roof. Your owners manual should have the exact steps you need.
Basebllstar is offline
SuperXero
Scion tC 1G ICE & Interior
02-23-2020 08:17 AM
CPL_Radar
03-05-2015 05:42 AM
evolving_machine
02-27-2015 09:53 PM
Cadillac15
01-29-2015 07:34 AM
evolving_machine
01-13-2015 08:04 PM
Quick Reply: Passenger Window and Moon Roof Won't Open
