Help with AVIC-F700BT Instalation
Hi all, I am trying to wire up my new AVIC-F700BT and I have no idea where the orange illumination wire hooks up. I already connected the orange/white dimmer wire from the Scion harness to the orange/white illumination wire on the Pioneer harness. Does the remaining orange wire on the Scion harness also hook up to the orange/white illumination wire on the Pioneer harness? My second question is about the reversegear signal input wire. Is it necessary to connect this wire, and if so, where does it hook up to?
I'd like to thank all of you in advance for the help, and I am glad to be a new member of your online community.
sometimes the navi system gets confused if you don't hook up the reverse wire, however most times it's not completely necessary.
the best area to connect your reverse wire that i've seen is a pink wire behind the glove box.
see link for details:
https://www.scionlife.com/forums/viewtopic.php?t=181678
as far as the illumination.. i can't remember which was which, but i only used one of the wires i think... i believe you can test if that wire is correct by going thru the navi and testing it though
TheRedBox
31
12-02-2003 04:53 PM
