Post Pics of Your tC System Here
Old 03-04-2013, 02:06 PM
  #1381
SDStance's Avatar
Originally Posted by thewalterwillis
Attachment 13265Touch screen pioneer deck/GPS in dash system Bluetooth
Where there any problems with still having the flap cover for the head unit usable? Im looking into double din in dash units and i really wanna still be able to use the flap door.
SDStance is offline
Old 03-04-2013, 08:18 PM
  #1382
GQQSE13's Avatar
the only thing you have to do (if you run into this) is in the bracket that you use, you make a new hole on each side of the bracket farther towards the front of the bracket so that it sits farther back.
GQQSE13 is offline
Old 03-04-2013, 08:32 PM
  #1383
SDStance's Avatar
Alright cool thanks! Kind of off topic but was wondering if anyone knew a site i could go for inexpensive reliable double din in dashes?
SDStance is offline
Old 03-10-2013, 12:40 AM
  #1384
toeveryhour's Avatar
Old sound setup:
*JVC KW-AVX706 DVD in dash
*JVC iPOD adapter
*Two 12" Alpine Type E subwoofers
*Alpine mrd-m501 amp
New sound setup completed in January 2013 (I got air, so the old had to go for the tank to fit):
*Eclipse AVN726E 7 inch touch screen receiver (with iPod, Bluetooth, GPS navigation, and DVD)
*JL Audio HD600/4 Class D 600 watt 4 channel amp
*JL Audio HD750/1 Monoblock 750 watt HD amp
*Four JL Audio 8 inch W3 subs
toeveryhour is offline
Old 03-10-2013, 11:47 PM
  #1385
GQQSE13's Avatar
sonicelectronix.com hookedontronics.com
GQQSE13 is offline
  #1386
GQQSE13's Avatar
nice set up toeveryhour
GQQSE13 is offline
Old 03-11-2013, 02:13 AM
  #1387
^Thanks!
Old 03-11-2013, 01:57 PM
  #1388
GQQSE13's Avatar
Originally Posted by toeveryhour
^Thanks!
glad to see i'm not the only one that switched to 8's (except i like your set up better thant he way mine's going to turn out )
GQQSE13 is offline
Old 03-27-2013, 02:34 PM
  #1389
anti_virus347's Avatar
Originally Posted by FamousxB
thats the look i always get... ppl get next to at the light and my music is down they turn there's up thinking that its loud and when i put mine up GAMES OVER!!!!lol Audiopipe is really making some sick subs, amps, and loudspeakers. you guys should check them out
Im in sales for a Hearing Aid Center. Im sure we will be talking very soon
anti_virus347 is offline
Old 04-19-2013, 07:43 PM
  #1390
GQQSE13's Avatar
my newest set up (and hopefully last after switching it up 8 different times in the last 6 years) 4-8's (Kicker CVR), 2-Kicker ZX350.4 and
1-Kicker 1500.1 powered by 2- kinetik 800c's in the hatch and 1-1400 under the hood
Attached Thumbnails Post Pics of Your tC System Here-img_20130406_173643.jpg
GQQSE13 is offline
Old 04-30-2013, 11:56 PM
  #1391
xdejablu3x's Avatar
Does anyone have problems with overheated amps in the trunk area, specifically the right side of the of the spare tire in the foam section? I was planning on putting an amp in there to have a clean look and to save space but worried about overheating issues.
xdejablu3x is offline
Old 05-01-2013, 05:51 PM
  #1392
GQQSE13's Avatar
i'm guessing you will hav ethe amp covered by the hatch 'floor'/panel? if so you probably will depending on how much you're trying to push and how long its running because it needs air to ventilate through it to keep it cool.
GQQSE13 is offline
Old 05-01-2013, 11:28 PM
  #1393
xdejablu3x's Avatar
That's correct. If anything I was thinking about cutting some small slits on the cover along the edge of where my sub box will be. Then put some sort of mesh underneath it.
Old 07-09-2013, 07:06 PM
  #1394
daxII's Avatar
New for 2013. Along the same lines as my last install, I'm going for loud, but with SQ in mind. After about a month of weekends, I finally got everything installed and dialed in. I also ordered some more RAAMAT so I can deaden the rear hatch. Luckily everything is loud enough to drown out any rattling, but I want to keep as much sound inside as possible. Even though it took forever, I also used tamper-proof hex bolts for the subs and amps, so if someone is stupid enough to try and lift any of my stuff, they'll be in one place long enough for target practice.
daxII is offline
Old 09-21-2013, 06:29 AM
  #1395
thehundreds702's Avatar
thehundreds702 is offline
Old 01-19-2014, 07:17 PM
  #1396
95maxrider's Avatar
Hey everyone, noobie checking in!
I'm seeing a lot of great pics of sub enclosures, but not much in the way of main component speakers. Excluding the guys who are building everything from scratch, what are people doing for speaker spacers/adapters? I've used those cheap ABS plastic ones on my Infiniti and wasn't very impressed, but I'm not sure what's available for your cars (1st gen tC specifically). Are shallow depth front speakers a common necessity with these cars?
Thanks!
95maxrider is offline
Old 03-01-2014, 05:41 AM
  #1397
DaTRican's Avatar
DaTRican is offline
Old 03-01-2014, 07:58 PM
  #1398
GammaTNT's Avatar
Thanks!
I cut a 1 inch board for an adapter.
GammaTNT is offline
Old 01-22-2015, 07:05 PM
  #1399
rideincircles's Avatar
What are the best options to get for replacing the speakers and deck for a 2005 TC?
I have finally blown out one of my front speakers and have had to eject cd's with tweezers for a couple of years since the eject function doesn't work correctly. It is time for an upgrade.
I would like to upgrade my sound quality, but I wasn't planning on getting an amp or subs since I throw bikes and fill my car up to the brim with camping gear on occasion.
Just seeing what is recommended if anyone has any input. I have never done any upgraded sound system work, but I still miss my old Infinity Spatial Imaging Sound system in my Chrylser LHS.
I was considering the Polk DB6501, but was not sure what all is needed to switch my speakers out. Do I need new tweeters, or will a better speaker take care of that?
Also, I was planning on keeping the door for the deck intact also.
I may check out Car Toys, but no one was around at Best Buy to answer any questions when I stopped by.
rideincircles is offline
Old 02-28-2015, 06:45 PM
  #1400
tckid21's Avatar
as for the speakers, speaker upgrades will do unless your doing a real build... Polk are fine for just every day use....
The deck on the other hand you can go either single din or double din. single din you'll just need to buy a buddy to fill the bottom portion. As far as the double din, some might not fit unless with modification. I had 2 eclipse double dins but it required me to grind down the rear of the door....
good luck...
and if you want subs, there are always stealth subs or small 8-10" subs and hide the amp next to your spare underneath or under your passenger seat.
tckid21 is offline
Quick Reply: Post Pics of Your tC System Here
