My audio is out, I need help
Old 03-29-2012, 07:42 PM
Damondogg's Avatar
Default My audio is out, I need help
My step daughters 06 TCs audio is out. No distortion
Whatsoever. I understand it could be a speaker harness problem or maybe the amp. I took it to my dealer, he tells me that they would have to charge me at least $90 just to look at it basically. Is that worth it? Can someone else tell me how much am I looking at spending if there's an amp issue or speaker harness problem?
Damondogg is offline
Old 03-29-2012, 08:10 PM
Josiah21TC's Avatar
correct $90 is the right price. that is the normal cost per hour of labor that a dealership charges. even if it does not take them an hour it will still be $90. my suggestion is to try and find a smaller local car audio place to have them look at it. it will still cost anywhere from $45-60 an hour for labor at those places too, but that is better then $90.
Josiah21TC is offline
Old 03-29-2012, 08:40 PM
Damondogg's Avatar
How much would an amp be if that was the case?
Old 03-29-2012, 08:42 PM
Josiah21TC's Avatar
well that depends. does the TC have the factory subwoofer and amp or does it have an aftermarket stereo system in it?
Old 03-30-2012, 03:02 AM
brandaman50l's Avatar
dont bring it to the dealer its a rip off. bring it to an audio place. you would have better luck bringing it to best buy
brandaman50l is offline
Old 03-30-2012, 06:48 PM
Damondogg's Avatar
My TC has the factory system.
Old 03-30-2012, 07:52 PM
Is it just the sub or the whole system?
Old 03-30-2012, 09:45 PM
Damondogg's Avatar
How much u think best buy would charge me since I have a factory system?
Old 03-30-2012, 09:46 PM
Damondogg's Avatar
It's the whole system. No distortion at all. Power comes on but no audio whatsoever.
Old 03-30-2012, 10:19 PM
Take the deck out there are 2 different wireing harnesses one for power and one for the speakers check and see if the speaker wiring harness didnt come out or come loose. if that doesnt fix it best buy will prolly charge you 30 tp 50 bucks for diagnostics good luck
Old 03-31-2012, 12:15 PM
Damondogg's Avatar
Thanks for your help!
Old 04-03-2012, 10:08 AM
Damondogg's Avatar
Can anyone tell me on how to remove the factory radio from 06 SCION TC? I figured I'd try it myself to save some $$.
Old 04-03-2012, 01:18 PM
abraves4410's Avatar
just remove the waterfall,(theres a diy guide to removing all the interior) and then its 4 screws to remove the hu. piece of cake. pull it out of the dash and check the wiring
abraves4410 is offline
Old 04-03-2012, 03:20 PM
TheMuffinMan00's Avatar
Our Tc's only have an amp on the factory subwoofer. If you don't have any sound at all you probably have a bad radio. When you turn the car on do you hear a quick pop from any speaker right as the radio comes on? If so that speaker may be blown and the radio is going into protection mode to save itself. If not the radio has probably gone bad. These radios are VERY simple to remove. If you go to metra.com and look up your vehicle there are instructions on exactly how to get them out. There is not a seperate plug for just speakers though. There is one plug that has all of your power and front speakers and one for just the rear speakers so if ALL of your speakers aren't working yet the radio turns on that is not your issue.
One thing you can try is to unplug the radio and let it sit for about 5 min. Then plug it back in and see if it works. Sometimes radio's do need to be reset just like a computer because they glitch but I haven't seen that from any scion's yet. Mainly GM radios do that.
I do work at best buy and will tell you that MOST best buys will diagnose it for you for 40 bucks at most BUT if you replace the radio they will waive that 40 if you get a new radio installed. That is what we usually do here at our store. Works out great for most people in your situation. That way if we fix it you just owe 40 and if you end up havign to replace it then you aren't out that extra money.
Hopefully this hleps.
TheMuffinMan00 is offline
carid
08-07-2015 11:32 AM
marsman328
Regional - Pacific Mid
07-28-2015 09:43 PM
Beesh
01-09-2015 06:30 PM
Quick Reply: My audio is out, I need help
