tC radio door squeak - Scionlife.com
Reply
Thread Tools Search this Thread
Old 10-10-2005, 04:26 AM   #1
Default tC radio door squeak
It's really bad on bumpy roads for me. Anyone fix this themselves? How do you do it?
RandomGuy is offline   Reply With Quote
Old 10-10-2005, 04:38 AM   #2
foxtransmission's Avatar
Default Re: tC radio door squeak
Quote:
you can take the unit ot and use some grease takes 5 seconds if its a manual did you change radio lately?i just pu a d-1 my door was squeaking but i put frame and sound seems to be gone
foxtransmission is offline   Reply With Quote
Old 10-10-2005, 04:42 AM   #3
It must be just the hinge or one of the rubber bumpers in the door system. Mine started squeaking slightly about a month ago and all I did was wiggle and tweak the door a bit and it went away for good.
Some of these little rattles and squeaks only needs a bit the owner's manipulation of the offending squeaky or rattley part to "fix".
I think people shouldn't waste their time going to the dealers for such minor things if it could only take a few minutes or even just seconds of your time to fix right in your own garage.
Chombi
Chombi is offline   Reply With Quote
Old 10-10-2005, 06:45 AM   #4
dieselstation's Avatar
i fixed mine by taking the door out. completely. i never use it anyways.
dieselstation is offline   Reply With Quote
Old 10-10-2005, 03:12 PM   #5
Quote:
How do you do this? How do you go about taking the head unit out?
Old 10-10-2005, 05:27 PM   #6
Scion Noics
indecisive311's Avatar
mine was really bad...just grease up the joints and springs
indecisive311 is offline   Reply With Quote
Old 10-10-2005, 05:27 PM   #7
SCIONPARTS's Avatar
I think theres a TSB on this.
SCIONPARTS is offline   Reply With Quote
Old 10-10-2005, 06:14 PM   #8
huh??? what squeak??
tc913 is offline   Reply With Quote
Old 10-10-2005, 06:19 PM   #9
Scion Society
TimmyT's Avatar
I think your squeek is comming from the vents above the HU. There is a TSB on that i believe
TimmyT is offline   Reply With Quote
Old 10-10-2005, 07:28 PM   #10
SCIONPARTS's Avatar
Quote:
ooh I knew something around there squeaked
Old 10-10-2005, 08:56 PM   #11
I think it's from the radio door because when I tap the door while it's open it squeaks.
Old 10-10-2005, 08:57 PM   #12
Quote:
How do you get to them? I am new to this, and I don't know how to remove the head unit.
Old 10-10-2005, 10:11 PM   #13
Scion Noics
unscrew shift ****
pull out shift bezel piece and unplug cig lighter
pull center piece straight out and unplug harness (door must be closed)
tada
Old 10-10-2005, 10:14 PM   #14
R2D2's Avatar
unscrew shift ****
tada
Sounds like drama...
R2D2 is offline   Reply With Quote
Old 10-11-2005, 12:42 AM   #15
Haven't had this problem yet, When you do fix it, let me know for future reference
TCSTYLING is offline   Reply With Quote
Old 12-18-2005, 12:25 AM   #16
Yanki01's Avatar
Sorry for the big gap in post.
this thing drives me crazy! Even with my bass pounding the crap out of my tC. i still hear this shi$! Is this cause from a HU upgrade? Any1 with the stock HU have this problem? I dont remember me having this problem when my stock HU was there? too long ago. I made an appointment with my dealer about this but idk if i should take out the aftermarket HU and put the stock one in? Please reply. cause im going nuts!
Yanki01 is offline   Reply With Quote
Old 12-18-2005, 01:31 AM   #17
RCFelix's Avatar
Mine squeaks too ONLY when it's open and going through bumpy roads BUT once I close it, the squeaks are gone! Lucky me...that's my only problem with squeaks, rattles, etc etc...I never had any noise with the wind deflector and hatch rattles like most people have posted here...I have a 2006...maybe they have fixed those problems that the 2005s were having.
RCFelix is offline   Reply With Quote
Old 12-19-2005, 12:36 AM   #18
Yanki01's Avatar
i think i fixed mine? (knocking on wood!) i just tightend the screws on the sides i guess where the little rotor moves, make that tighter and spray some WD40 type stuff and your good. I hope! Dont take my word on it.
Old 12-19-2005, 10:52 PM   #19
PrivateTucker's Avatar
Good deal. I fixed mine by placing rubber bumpers in 4 different locations. I placed 2 inside on each side in the back in the way of the door fully opening, and I placed 2 more between the vents and the thing below them. No more squeak.
PrivateTucker is offline   Reply With Quote
Old 12-20-2005, 03:27 AM   #20
Just get a tcover... auto door... never squeak.
-Keith- is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
tC: FS: 2005 tC - 154K - TSX Conversion - TRD Goodies minter66 PPC: Vehicles 0 12-15-2014 02:45 PM
xB Wiring Color Codes and Locations Inazuma Scion xA/xB 1st-Gen ICE & Interior 19 01-31-2007 03:39 AM
Here's the wiring diagram for the xB. In case anyone needs wonderworm Scion xA/xB 1st-Gen ICE & Interior 5 01-19-2004 09:54 PM
Tags
center, console, cover, door, head, radio, rattle, remove, scion, sound, squeak, squeaks, squeek, sticks, tc, unit, wwwstickcomtcradio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
