Fixed stubborn Sunroof switch when closing Sunroof..
Old 04-14-2015, 11:18 PM
mc1114's Avatar
Default Fixed stubborn Sunroof switch when closing Sunroof..
Fixed the prevalent stubborn sunroof switch issue. When attempted to close, it would take a lot of pressure or many tries to get it to move, due to not enough contact between the moving outer part and the inner little black buttons
Put a small dab of JB Weld on top of each button that closes the sunroof, for better contact. It now works flawlessly
mc1114 is offline
Old 04-14-2015, 11:35 PM
electrongeek's Avatar
That's a nice little trick! Thanks for sharing!
electrongeek is offline
Old 04-16-2015, 12:31 AM
yupinmytC's Avatar
is there a thread on how to remove the panel?
yupinmytC is offline
Old 04-16-2015, 02:12 AM
mc1114's Avatar
Its all easy to do. Whole assembly just snaps into the roof, and can be pulled down by prying with a little screwdriver. Then the circuit part gets separated from the outer part with a small phillips screwdriver
mc1114 is offline
Old 05-04-2015, 12:34 PM
Yakoma's Avatar
Smart fix...good job
Yakoma is offline
Old 05-08-2015, 01:06 AM
danielv's Avatar
Thanks OP! I've been having problems with my sunroof not opening at all and this completely fixed it.
danielv is offline
Old 01-24-2020, 08:26 PM
Scion2014T's Avatar
Default Sunroof problem
Is JB Weld the only thing you tried? Is there anything else that might work?
Thanks.
______
Scion2014T is offline
Old 04-23-2020, 10:34 PM
scydmarc's Avatar
The part listed below appears to be the same switch as what's on the PCB. I plan to order some soon and solder them in to replace the old ones. I'll be getting 4 to replace both of the switches for open and both of them for close. I had previously added a few layers of tape to the plastic that pushes the buttons down to make it push them harder, but after a while it stopped working reliably. After I opened it up again, I found that both of the switches for close have to be pushed very hard before they make contact now. And when they do make contact, they have a higher resistance than the switches to open the sunroof do. So I think they are actually worn out. Anyway, the parts below seem to be an exact match from my measurements. I'll report back when I test it out.
Digikey part # P15958SCT-ND
Manufacturer part # EVQ-PV205K
scydmarc is offline
TonyCanton
02-07-2008 07:41 AM
elite-fusion
10-05-2007 05:51 AM
Damondogg
06-08-2007 11:41 AM
DouBLeJ16
04-05-2006 11:20 AM
gavmitchau
04-02-2005 04:59 AM
Quick Reply: Fixed stubborn Sunroof switch when closing Sunroof..
