How do I replace brake tail light bulb?
Old 01-26-2011, 01:06 AM
TinmanTC's Avatar
Default How do I replace brake tail light bulb?
Tried googling but end up with 10000 led/third brake light bulb matches.
All i wanna do is replace my burned brake light. I believe its a 7443 bulb.
What do I do?'
thanks
TinmanTC is offline
Old 01-26-2011, 01:11 AM
draxcaliber's Avatar
check you're owner's manual?
never had to do it since mine have never burn out, but i imagine you open the hatch, pop over that little cover on the inside of the corner behind the taillight and twist the dead bulb out, and replace it.
it is almost as hard as...changing a lightbulb.
draxcaliber is offline
Old 01-26-2011, 04:04 AM
Spicy_McHaggiz's Avatar
Owners manual tells you how, but in case thats to simple or hard, here you go.
1) Pop the rear hatch
2) In the corner where the back of the tail lights are you see 2 covers with plastic tabs. Pull those tabs out and the entire panel comes out. (yes the fuzzy things)
3) Twist and pull the correct socket that corresponds with that in which is burnt out.
4) Reassemble the same way you put it together.
Spicy_McHaggiz is offline
Old 01-26-2011, 04:09 AM
MANiAK's Avatar
I believe he's talking about the trunk/3rd brake light
EDIT: my bad, you're right -.-
MANiAK is offline
Old 01-26-2011, 06:10 PM
TinmanTC's Avatar
thanks
TinmanTC is offline
TheTripleC
01-04-2015 06:46 PM
mrbadass03
24
04-21-2004 02:17 AM
Opr8r
20
02-25-2004 11:29 PM
Slopoke21m
10-02-2003 04:59 AM
randode
16
10-01-2003 12:40 AM
Quick Reply: How do I replace brake tail light bulb?
