lights on the outside how do i get constant power to the inside with a swithc
I have a2005 scion tc and i have grill lights that i am currently installing and i need to find the constant power on the inside so i can use a switch to turn it on or off without the key in the ignition..
Here's one option:
http://www.ebay.com/itm/ADD-A-CIRCUI...item2a38585a68
Pull the mini fuse from an always-on circuit. Insert fuse tap into the vacant slot. Insert the fuse you just pulled from the panel into the first slot of the wire tap. Add a second fuse for the switch you're installing.
Try to match the amp rating of the grill lights with the tapped circuit.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
hampton1100
05-28-2015 07:32 AM
missing_image
02-07-2015 07:18 PM
