Bad Vibration and shaking
I have a 2008 Scion tc and recently have a really bad vibration & shaking in my right front wheel area. I know it is not the tire, thought it was so had new one put on, and has gotten worse over last month. It shakes right from the moment car starts moving and gets worse as speed increases. When turning/merging to right it goes away & is bad when going straight, and worse to the left. Can anyone help me with this issue and wonder if problem is something I could fix on my own. I have ideas, but really could use your help. Thx for your time!
If it is the tie rod, is that something possible that can be replaced fairly easily or should I have a garage do it? I'm really good at figuring out how to repair, but don't know how extensive of a job it is? Guessing obviously? Is it possible that's its something else? Ex....spindle or bearings?
x2 on cv shaft that might be bent causing the vibration issues. or it can be a bent control arm..have a shop put it on a lift and find out what the problem is. you dont want to go guessing around especially when it's suspension components.
I am curious if steering noise is in my column is related to possible CV issues? I was told i need to replace both the drivers and passenger side. I know there is a bracket attached to the drivers side and steering column, so curious if that could be the culprit?
Well not much more to say i don't think. If a mechanic already said i needed to replace CV on both sides what "other" details am I missing? I already asked if anyone thought the bracket might be the problem... besides starting another thread on the same topic seems redundant considering I have already acknowledged I am having similar noises?
BlingSlade
10-19-2016 12:39 AM
Klashan
09-24-2015 12:39 PM
