function & form vs h&r
Old 03-15-2010, 10:00 PM
fatboitan's Avatar
Default function & form vs h&r
I'm looking to have a tuck look and also keep my ride as comfortable as possible on coilovers since my tc is a DD which i drive about 40 miles a day on freeway. Can you guys give me the pros and cons of each coilovers and a final decision on which you would pick?
fatboitan is offline
Old 03-16-2010, 01:03 AM
203superwhitetC's Avatar
I have the H&R's on my car right now and I've had them for a year and I love them. You'll get a bit of a tuck if you max them out but not much. I plan on getting the Function and Form V1's and I think it's a similar drop. Apparantly the F&F's have a maximum of a 3inch drop and I plan on maxing them out haha
203superwhitetC is offline
Old 03-16-2010, 01:17 AM
chicotunner07's Avatar
^the F&Fs go lower then H&Rs, but by a hair! although you have to mod them, (remove 2 rings and compress the spring)
also the F&Fs have independent height/shock travel adjustments, basically, my V1's are slammed yet i still have full shock travel, the H&Rs you would loose almost all of your shock travel increasing the chances of bottoming out or possibly lowering shock life!
but as you can tell im biased to the F&Fs, DQLOSTSOULS should give you the best advice as hes acctually had both!
btw: if you can still get the F&Fs V1s from assaultech for the GB price like i did, go for them, the price is soooo cheap its unbelievable!
chicotunner07 is offline
Old 03-16-2010, 01:23 AM
dqlostsoulz's Avatar
I had H&R's and they are really nice I liked them. The rears go lower than the fronts. Although I removed a perch ring from the fronts to get a slight tuck...
And I am now on F&F's which ride about the same except for more cluncking when I turn the wheel. However I modified the fronts and removed 2 rings and compressed the springs.
Overall I would say I liked the H&R's better....just wish they went moar low. Both sets did not go low enough for my liking!
dqlostsoulz is offline
Old 03-16-2010, 01:42 AM
fatboitan's Avatar
i made a mistake by saying tuck i meant flush...both would be able to do that since they are capable of tuck correct?
Old 03-16-2010, 01:44 AM
Flushness depends on your wheels
Old 03-16-2010, 01:57 AM
^yeah, flushness is all about wheel offset, coils basically allow you to slamm your car, also another plus for the F&F is they have top camber plates up front which will help with adding negative camber for wide wheels with low offsets
Old 03-16-2010, 01:59 AM
fatboitan's Avatar
i'll be on stock for a while so what you guys think?
Old 03-16-2010, 02:05 AM
B&G's
Old 03-16-2010, 02:14 AM
fatboitan's Avatar
out of my budget haha i was also looking at bc racing coilover since my bro just got it for his 09 honda accord coupe. It made his car sit perfectly flush on stockies
Old 03-16-2010, 02:42 AM
B&G's
LOL, i knew you were gonna throw those out there, lmao
Old 03-16-2010, 02:44 AM
hahah...and you know this man!
Old 03-16-2010, 03:10 AM
fatboitan's Avatar
dq was your car slammed or flushed with the rims?
Old 03-16-2010, 03:13 AM
I am as low as they go and poke...just check out my pics in my sig under my ****!
https://www.scionlife.com/forums/sho...158560&page=45
Old 03-16-2010, 03:53 AM
RoboCop's Avatar
fatboitan, what's your definition of flush. It seems you don't know what it means.
RoboCop is offline
Old 03-16-2010, 04:02 AM
fatboitan's Avatar
the look im going is for the top tire to be at where my fender start. I don't it to be underneath the fender. So whatever term that is that's what i'm looking for as a stance.
Old 03-16-2010, 04:10 AM
DJ08tC's Avatar
flushness i from the wheels, yes you have to have coilovers that will go low enough but if you have weak fitting wheels like stock it will be sunk in behind the fender.
maybe someone else can explain it better.
DJ08tC is offline
Old 03-16-2010, 04:35 AM
RoboCop's Avatar
Flush is having the face of the wheel lining up with the fenders. What you are looking for is zero finger gap.
RoboCop is offline
Old 03-16-2010, 11:33 PM
CinSity Scions
mystik's Avatar
for a zero finger gap, H&R and F&F will both do the job. the F&F are better though cuz you can adjust damper (stiffness) while in the H&R you cant. and also like someone said before, F&F have independent shock travel.
mystik is offline
Old 03-16-2010, 11:37 PM
fatboitan's Avatar
oh so many choices my bro just got bc racing coilovers and it's about a grand plus you can adjust damper
Quick Reply: function & form vs h&r
