FR-S Stock Wheels mounted on tC1
Old 05-27-2013, 09:21 PM
Jar
Jar's Avatar
Default FR-S Stock Wheels mounted on tC1
Well, I've seen a few postings here and there asking if it can be done, but no one post actually providing all the information needed to actually do it. I just got finished mounting the wheels on my 06, so here are the details.
tC1 Wheel
17x7 +45mm Bore 54.1
FR-S Wheel
17x7 +48mm Bore 56.1
The FR-S has a larger bore and is inset 3mm more than the tC wheel. If you try to place the FR-S wheels on the front, the wheel spokes will interfere with the brake calipers. The rear wheels clear the calipers with no issues.
In order to clear the calipers and bring the wheel out a bit more than stock, I decided on 10mm spacers all the way around. A 5mm spacer will allow it to clear the caliper, but the spindle shaft will push out the center cap of the wheel.
I ordered the spacers (Hub Centric to Vehicle and Wheel Centric to Wheelspacers) from here:
http://www.motorsport-tech.com/4DCGI/wheel_spacers
Now, that I have spaced out the wheel, the stock length studs are no longer sufficient for threading the lugnut. I could only get about half a thread with the spacer in place.
I ordered the Ichiba +50mm (TO-12550) studs from here:
Amazon.com: Ichiba Extended Wheel Stud for Lexus/Scion/Toyota +50mm: Automotive Amazon.com: Ichiba Extended Wheel Stud for Lexus/Scion/Toyota +50mm: Automotive
Once I replaced all the studs, the wheels went right on, with no rubbing or clearance issues. This is with TRD springs.
Jar is offline
Old 06-07-2013, 01:05 AM
KolonelKoRn's Avatar
Hey I have a question about the amazon extended studs. Is the price for individual studs or a whole set or just one rotor?
Edit: Scratch that I can see that it's for single studs. Another dumb question until I'm able to call the motorsport-tech guys. It's a hubcentric ring and spacer in one right?
Thanks
KolonelKoRn is offline
Old 06-07-2013, 08:45 PM
Jar
Jar's Avatar
Thanks
You got it.
Jar is offline
Old 01-10-2014, 08:49 AM
mightyherc21's Avatar
Default FRS wheels to 2008 tC
I think that looks great and was considering doing that to mine...
Thanks for the info on what you did!
I'm a noob, so when I order the spacer, I want the bore dimensions of the FRS wheel (56.1), right?
mightyherc21 is offline
Old 01-10-2014, 01:36 PM
Jar
Jar's Avatar
The website will walk you through the steps, but essentially, you will pick your year/make/model (it will know the correct diameter for the tC), the thickness of the spacer, and then the bore of the wheels you want to adapt. You should end up with something like this:
Spacer Configuration
2006 SCION TC
Your Bolt Pattern: 5x100mm
Your Hub Diameter: 54.1mm
Type: Spacer
Hub Centric to Car & Wheel Centric to Wheel
Thickness: 10mm
Center Bore: 56.1mm
Jar is offline
Old 01-10-2014, 02:30 PM
FIREDOG21's Avatar
^^ That's looks sharp!! Might get those for my summer wheels!!
FIREDOG21 is offline
Old 01-10-2014, 04:16 PM
Thanks for the info!!!
Old 01-27-2014, 07:33 PM
that_G_U_Ys_tC's Avatar
Nice not bad, I'm looking in a different direction but did wonder about this idea,
that_G_U_Ys_tC is offline
eric_m
52
01-17-2019 05:50 AM
scionlife
371
06-02-2015 11:00 PM
darkshadowofxdeath
12-03-2014 06:59 PM
yanges
09-30-2003 02:31 AM
Quick Reply: FR-S Stock Wheels mounted on tC1
