Steel Rims
Old 09-17-2014, 04:23 PM
skruff's Avatar
Default Steel Rims
Hello all,
I recently purchased a pair of used blizzak winter tires. They are 15 inch and are mounted on 15 inch steelies with a 4x100 bolt pattern. I checked the outer diameter of the tire and calculated that they're less than 1% different from our stock tire size so I'm alright there.
Since they are mounted on tires with an incorrect bolt pattern, I've been calling around looking for a set of 15 inch steelies with a 5x100 bolt pattern (since that's the size I've seen come up every time in a search on here)
However, I have had two shops now tell me that the tc has 5x114 pattern and that I'm looking for the incorrect size.
Can someone please confirm that I can get 5x100 15 inch rims and mount my winter tires to them?
I have an 06.
skruff is offline
Old 09-17-2014, 08:52 PM
crg5990's Avatar
Yes all first gen (05-10) tC's are 5x100 bolt pattern so as long as you can find 15's in that pattern then you'll be fine
crg5990 is offline
Old 09-18-2014, 10:09 PM
skruff's Avatar
Thanks you!
skruff is offline
Old 11-22-2014, 01:26 AM
DoinItWright's Avatar
Look for corolla wheels. Same bolt pattern if its from the 05-08 range, and almost all ran 15's.
DoinItWright is offline
dougcbx
10-23-2015 11:42 PM
peruviann
09-14-2015 06:35 AM
Robineileen324
09-14-2015 06:21 AM
JZA70
09-12-2015 09:37 PM
vintage42
09-12-2015 12:59 AM
Quick Reply: Steel Rims
