Taking rear hub off
Old 02-23-2013, 10:19 PM
doublem94's Avatar
Default Taking rear hub off
Hey guys. Trying to change the rear wheel hubs on my gf's car. Piece of cake until I try to pull the hub off. I'm using a slide hammer I rented from AZ and nothing. Tried hitting it from the back with a hammer, drenched it in pb blaster, put the wheel back on and tried to pull; nothing. I read most threads on here; everyone says to keep trying but still nothing. Anyone have any ideas? I didn't n heat it b/c of all the pb blaster all over. Is it hard to take the e-brake assembly off and maybe try to pry it? Thank u in advance for any suggestions.
doublem94 is offline
Old 02-24-2013, 12:06 AM
Dam262a's Avatar
keep trying, its just rust
Dam262a is offline
Old 02-24-2013, 01:16 AM
RoboCop's Avatar
once sprayed on, pb blaster won't catch fire. At least it didn't for me. I am not responsible if your car catches fire or is damaged.
RoboCop is offline
Old 02-24-2013, 10:08 PM
doublem94's Avatar
Thx for the suggestion guys. Unfortunately, even after applying mapp heat it still won't budge. Any specific spots to apply the heat. I went from the back of the hub, the screw holes and whatever I could from the front between the ebrake. I've done a couple hubs before but this one takes the cake. I refuse to give up but this ____s driving me crazy. Is it hard to take the ebrake mechanism off?
The AZ slide hammer adapter can only fit on one lug. Should I look for one with two or more for more resistance? Thx
Old 02-25-2013, 11:56 PM
Dam262a's Avatar
Find a long lug or lug and socket and smake it off with a sledge hammer
Dam262a is offline
Old 07-24-2016, 09:28 PM
keithmass's Avatar
Default easy removal of rear hubs
[QUOTE=doublem94;4091354]Hey guys. Trying to change the rear wheel hubs on my gf's car. Piece of cake until I try to pull the hub off. I'm using a slide hammer I rented from AZ and nothing. Tried hitting it from the back with a hammer, drenched it in pb blaster, put the wheel back on and tried to pull; nothing. I read most threads on here; everyone says to keep trying but still nothing. Anyone have any ideas? I didn't n heat it b/c of all the pb blaster all over. Is it hard to take the e-brake assembly off and maybe try to pry it? Thank u in advance for any suggestions.[/Q
pierce the ABS back cover with a screwdriver and pry it off,there is a hole on the rear control arm it takes some force but once removed take a punch from behind and the wheel bearing will come right off,make sure you remove the 4 12mm bolts,the ABS has a snap ring inside that you need to break from prying and POW your hub will be laying on the groung
keithmass is offline
Old 07-24-2016, 09:39 PM
keithmass's Avatar
you DO NOT have to take the E brakes apart either
Old 07-24-2016, 09:43 PM
keithmass's Avatar
peirce the black ABS cover with a screwdriver an pry it off there is a snap ring inside ABS cover once you break that take a punch and hit center of ABS rind and POW your hub will be laying on the ground...
Old 07-24-2016, 09:47 PM
keithmass's Avatar
no heat is required at alltrust me it is so simple once you know this trick
Old 07-27-2016, 02:42 AM
Dam262a's Avatar
[QUOTE=keithmass;4177166]
you do know this post is from 2013...He might of sold the car already lol
Dam262a is offline
Old 04-06-2017, 06:09 PM
chibi02's Avatar
here is a video about it
chibi02 is offline
Miqmiqmiq
01-15-2015 03:30 AM
tapetheducks
Scion xB 2nd-Gen Wheel & Tire
01-14-2015 06:25 PM
evolving_machine
01-13-2015 08:04 PM
2fixA
14
08-26-2007 05:10 AM
Slopoke21m
54
04-23-2007 12:25 AM
Quick Reply: Taking rear hub off
