DIY: Replace Flasher Relay to Avoid Hyper Blinking with LED Turn Signals
#41
#42
#43
Yes! Avoiding everything Scion202 had to do! I. Surprised he didnt go this route...he seems to be very in tune with car wiring.
And the flasher doesn't have anything to do with switching to LED tail lights. Just make sure you get CK-type bulbs and it is a quick swap. There is a thread on LED tail lights in the owners lounge.
#44
hey if u have time can u PM everything u know/what i need to get to do a complete exterior led swap (i only have the reverse and license plate lines done) thanks!
#52
I know that several sites sell the CF-18 flasher, but I got mine from v-leds:
http://www.v-leds.com/resistors-flas...ignal-fix.html
Mainly because it specifically stated that the lock/unlock confirmations WILL work.
Getting the old flasher unplugged was a bit of a pain with the awkward work space under the dash. I had to pull the stock one off of the frame where it was attached so I could get it unplugged. You guys will see when you get under there lol.
Anyway, my preliminary tests results were very promising...as expected!
I unplugged one of the blinker bulbs from its socket and turned that blinker on with the stock flasher. It hyperblinked as it should. I swapped flashers and did the same test...no hyperblink!! It flashed at it's normal rate. With that being said, obviously we lose warning if we have a bulb out. That's not really a concern though because we are all so in-tune with our rides that we'd notice very quickly.
Also, the keyless entry lock/unlock confirmations work as they should
Can't wait to plug in these LEDs when they arrive on Tuesday to see the real deal!
#53
so I've got the same relay a you steve... but something seems weird... it seem like the blink rate is actually slower than the stock blink rate... somehow it seems a bit too slow after switching the relay... thoughts?
#54
I believe i know exactly what you are referring to. For me, the initial blink is like .5 seconds longer than normal. After that though it is close to stock for me. Perhaps a little slower, but not very noticeable after the first blink. Is that what you are talking about?
