Overreved and lost all my torque
I was in 4th gear and trying to get to 5th I slipped it into 3rd gear by mistake. Overreved past the limiter for a split second.
Now, I lost most of my torque. I mean, the torque curve is linear now. There is no more torque at 4k than at 2k. And 0-100kph is done in 12s instead of ~8s. The exhaust sounds different too. It's like a very faint Subaru Boxer-ish low rumble when giving it gas. I don't know if I explain it correctly.
There ain't no check engine light. I drove ~50km back home after the incident and nothing bad happened, and the check engine light didn't come up.
Any thoughts? I only have like 6500 km on this engine
Torque obd2 scanner app shows catalyst check, evaporative system check and o2 sensor check as "incomplete". They were just fine before the incident.
Sent from my Nexus 4 using Tapatalk 4 Beta
Yeah, sounds like you'll need a new engine. Also, there is probably an event data recorder that has logged the engine revving past redline.
That is driver error, not manufacturer error, you messed up, don't try to make Toyota pay for something that you did. It is stuff like this that drives up the price of cars for warranty claims and makes it harder to get legit items covered.
Oh, also, Toyota/Scion is on here. not sure how active, but you know, be aware.
Ok but the engine would overheat with a malfunctioning water pump no? And, according to various forums posts and sites I googled today, a loss of power together with a Subaru-ish sound means bent valves almost every time.
thats what we thought also and we didn't see any antifreeze leaks anywhere. expected to see antifreeze at least on the floor but never seen any. we took off the passenger front tire and noticed dried up antifreeze on the engine. we took it to the dealer they said the antifreeze wouldn't leak onto the floor because the way its designed it basically squirts the antifreeze upwards and you would see a mark on the hood headliner . you would basically see a faded line on the liner above the belt and water pump.
Blown a Rod or Damaged your Valve train.
I seen a post about a mis-shift here before and the person opened his valve cover and some of the "things" got off track, he put them back and tightened her back down and was ok.
Edit after reading: Lol this ain't no water pump problem.
Good luck at the dealer, please post asap.
I think you should do a compression check. Then if that is looks ok, check the valves. Atleast valves are your top half and you should be able to fix those in your parents garage.
I consider you lucky being able to drive home. Most people end up with a piston rod through the oil pan...
As for the checks saying incomplete, you had just reset the ECU when you unplugged the battery. It takes around 25-35 miles to reset the ECU. After that, reevaluate how the car is acting. If its still acting the same way, take the car to the dealer.
I honestly don't think you broke anything. I've downshifted from 2nd to 1st way above where I should've been when transitioning to 3rd gear, my car was and is still fine.
But I think something must be broken because I don't feel the power it had before the incident. The difference is quite big IMHO. And it sounds like a Subaru, another hint at bent valves. The idle is rough. I can feel the exhaust pipes shaking underneath the car.
I'll have a look for the water pump tomorrow.
