Transmission noise? Clutch? WTF
Old 07-30-2015, 11:27 AM
  #101
element6's Avatar
Originally Posted by Mgraves22
Not 100 % if we have the same problem but I was talking to a guy I use to work with at toyota and there seems to be a problem with the 2nd generation tc input shaft bearing. There have been a lot of people bringing in their TCs for transmission noise. Most mechanics diagnosed it as a throw out bearing but fail to fix the problem. Unfortunately for me the only one person in my area has actauly fixed the problem and it's the input shaft bearing which is pretty much what allows the main gear shaft to turn and you have to open the transmission to fix it. It's actually only a 30 dollar part but not something you want to mess with if you are not experienced with transmissions. From what I heard toyota is thinking about doing a recall on that part but unfortunately this isn't something you want to wait to fix. If the bearing ceases up completely it will bore a hole in your transmission and then well... you'll have to get a new one. Anyway hope that your problem isn't a server
I have the same issue but have been reluctant to bring mine in due to people's experiences here and other places. The new part most likely will fail and provide the same result, the transmission sounds worse then it did before or the dealership just refuses to fix citing no issue was found (I have had that before).
I'm hoping Toyota further acknowledges there is an issue and finds a better solution then to repair with the same part only to have it fail as well.
element6 is offline
Old 08-04-2015, 07:20 PM
  #102
citystars41's Avatar
scheduled service for mine next wednesday. we'll see what they say
citystars41 is offline
Old 08-13-2015, 08:46 PM
  #103
yupinmytC's Avatar
most likely the bearings, do you downshift? probably redlined it a little to hard one time
yupinmytC is offline
Old 08-28-2015, 07:21 PM
  #104
took it in to the dealer and they say its the throw out bearing.... not covered under warranty and wants $1600 for the repair
Old 09-01-2015, 07:46 PM
  #105
carbinefreak's Avatar
If it doesn't make the noise when sitting still with the clutch in its not the throwout bearing. that only makes noise when it gets loaded aka when you push the clutch in.
carbinefreak is offline
Old 09-02-2015, 12:39 PM
  #106
yea made sense to me but a "professional toyota mechanic" must know better than that....
anyways, RussianKid pulled through for me. He got me a copy of the tsb. anyone else that may need it, here is the info:
TSB: S-SB-0008-13
DATE: 2/14/2013
Growling Noise with Cutch Pedal Released
File Type: pdf
Old 10-05-2015, 04:53 PM
  #107
JordanOfGilead's Avatar
I test drove one yesterday and noticed the same noise when coasting in 2nd and 3rd with the clutch in. Thought it was just in my head. Now I am seriously reconsidering trading in for a tc...
JordanOfGilead is offline
Old 10-08-2015, 05:11 PM
  #108
TheManinDboX's Avatar
If you hear the noise, don't buy the car..
Find another one and look at that.. Or just buy a new one, since the interest rates are lower on new anyway..
TheManinDboX is offline
Old 10-08-2015, 07:50 PM
  #109
The one I ended up with was brand new fresh from the factory and has no issues. I think the one I test drove was a MY15 that had the crap beaten out of it by a bunch of people doing exactly what I did.
Old 10-08-2015, 07:53 PM
  #110
when i test drove the XB1 i chirped 2nd every time i shifted it to annoy the dealer.. It was fun.. hahahaa..
Old 10-08-2015, 08:01 PM
  #111
I made sure to turn off traction control and light it up leaving the parking lot. He was not amused ...
Old 10-09-2015, 01:09 PM
  #112
Hahaha.. Awesome!
Old 06-07-2016, 06:24 PM
  #113
StatuSCheckA's Avatar
Why. I believe stock warranty states 5 years or 60,000 Miles. Were you passed that?
If Toyota will do it for $1600, a reputable shop would probably do it for $900. They don't have to drop the tranny for this.
StatuSCheckA is offline
Fisqual
09-22-2015 05:51 AM
nazblue5807
04-11-2015 12:20 AM
gularti
12-04-2014 01:21 PM
TheLeprechaun
19
04-03-2004 03:18 AM
ncscion
02-22-2004 09:26 PM
Quick Reply: Transmission noise? Clutch? WTF
