DESCENDANT tC2 Turbo Kit
#141
Se dice engine stall, asi kiza te puedan ayudar mas rapido. Te aconsejo cambiar a EMS 2 aunke el idle o baja aun lo controla la computadora de tu carro en la FIC y la EMS aunke con la EMS puedes tocar algunas otras cosas para controlar un poco la baja. Has un data log y verifica a ver si hay algo extraño.
#142
hacho mano es q la EMS2 esta carita y cn la rabiza se van pal de peso mas sumando el kit lo estoy considerando cm quiera pero seria luego.
tengo un compa~ero q te conose por tu XB Descendant
nada este es mi email b.collazo04@hotmail.com estoy en un grupo de Tc2 que vamos a estar presente en el hellaflush no se si ira si te interesa algun dia q vallamos a dar vueltas q le damos la vuelta ala isla me dejas saber la pasamos super bn y son personas seria no anormales jejeje te me cuidas y gracias por el consejo
#143
#145
There was a snorkel thing made by descendant that runs from your center grill to the IC so you can run the fogs but without it yea my fogs are currently out or you could always order the halo eBay fogs with the hollow center
#146
the problem is descendant now is with mercedes :/
#151
#154
Booost
I'm finally at the point where I/h/e, pulley, and twm shift kit is just not enough. I have a good bit of money saved and I'm in the market for a turbo kit, can anybody point me in the direction of vendors who can give me some pointers and honest knowledge before I dive into this? Thanks in advance
13' tc2 cement gray
13' tc2 cement gray
#156
I know this is meant for the Scion, but would it work with a 2ar-fe camry? There's been some talk between me and some friends about swapping in a manual trans, building the engine a bit and then using the descendant turbo kit but I'm not entirely sure on what all goes into actually adding a turbo to a car, don't really get to mess around with 'em much at work. The camry i'm thinking about using is 2011, currently automatic base model (LE). Nothing is done at this point, headers, cat back, intake and suspension parts are coming in the next couple of months. Any advice given or hints as to what I might do next would be greatly appreciated!
cessblood
09-15-2015 06:50 AM
my06tc
06-25-2015 12:18 AM
2011, carb, catback, decendant, descendant, descendent, exhaust, kit, kits, racing, scion, tc, tc2, turbo, turbocharger
