Scion tC 2G Forced Induction Turbo and supercharger applications
PTUNING: 2011 Scion tC Turbo Kit (Available to ship)
Old 10-27-2010, 07:53 PM
PTUNING's Avatar
Default PTUNING: 2011 Scion tC Turbo Kit (TONS of updates! on pg #1)
We just received a brand new 2011 Scion tC (Black) w/ manual transmission from a local Scion dealership to do a full build.
The build will include but not limited to:
*Turbo Kit
*Full 3" Exhaust
*Suspension
*Wheels & Tires
Before starting the build, we though we get some baseline pulls.
Below are the result & some added pics of the tC2 on the dyno:
Bone Stock 2011 Scion tC w/ Manual Transmission = 159 WHP @ 153.7 TQ
(The temperature in the dyno was 72 degree)
PTUNING Update 4/25/2012
We have decided to condense all the information from this entire thread, into the first page. This way all of the scion community can easily view our thread. We felt this would be much more accommodating instead of sifting through 20 pages for detailed information.
Kit Contents
PTUNING: tC2 Spec-SS Kit Contents.
-PTUNING Full S.S Turbo Manifold (With Wastegate flange.)
-PTUNING Aluminium FMIC piping Kit (Flange for Turbosmart BOV, and Maf sensor)
-PTUNING Front Mount Intercooler (24" L x 8" H x 3.5" T)
-PTUNING P_N_P Harness
-PTUNING OBD2 Down Pipe (Flange for OEM S-Pipe)
-PTUNING SS Dump tube
-PTUNING T-bolt Clamps
-PTUNING 4 ply Silicone couplers
-PTUNING Billet Battery Tray (Battery Extra)
-PTUNING02 sensor extension kit
-PTUNING Spec: Garrett T3/T4 57 trim trubo with .82A/R housing
-AEM FIC Controller
-Turbosmart Race Port BOV
-Turbosmart CompGate Wastegate (45mm)
-DW 550cc PnP injectors
-Spal Pull type Radiator Fan kit with install kit. ( 14" inch fan)
FAQ:
-Instruction Manual link: http://www.ptuning.com/Product_Insta...-MAN-10001.pdf
-After market Radiator: Not needed. Our current tC2 turbo kit is boosting daily with no heating issues.
-FMIC: Was designed with full bolt on capabilities. No cutting, or trimming needed.
-Tuning: The kit will come with a base map. Custom tune recommended.
-Turbo Charger upgrades available.
Manifold Pictures:
Merge Colleter: 304 Stainless Steel thick-wall equal length manifold with narrow angle twin scroll merge collectors.
Merge Collector:304 Stainless Steel CNC machined Turbine Inlet flange (1/2" thick).
Flange: 304 Stainless Steel CNC machined 3D header flange (1/2" thick).
Installed Kit Pictures:
Dyno Pictures:
Dyno Graphs Pictures
Lustin tC2: (PTUNING's first ever turbo'd Scion tC2)
Mods:
-PTUNING turbo kit
-Stock Clutch
-Stock Fuel Pump
-Stock S-pipe with cat
-Stock exhaust
Modeltc:
Mods:
-PTUNING turbo kit
-Stock clutch
-Stock fuel pump
-Stock S-Pipe with cat
-Stock exhaust
Dyno Video:
Driving Video:
Facebook Post
Customers personal installed kit pictures:
Customers comments
Here's a preview... I have a few things to work out but nothing special. As far as how it runs? Not the same car, not even close. Still getting used to being boosted - 2nd gear...pay attention, 3rd gear...lay on it and feel it, 4-6...better by sure no one is taking your picture because you are breaking the law . The power level is exactly what I was looking for out of a DD. Will I look for more? Sure, but not till XMAS.
Quick update - Several hundred miles on the car since getting PTuned. No CELs. It's getting 26-30MPG. Will update after next fill-up. The mid-range on this setup is STOUT and indicative of PTunings turbo sizing. It pulls so hard in 4th and 5th to the point where I think I may have some clutch slippage - need to verify after turning off TSC/VSC. For a DD I can't ask for anything more. Need to pass someone? Not an issue - hit it. Cooling fan came on for a couple of seconds after some stop and go traffic at 66 degrees outside. Moved the car 10 feet and the fan shut off. Overall - this setup is killer for a DD. BTW - I did not opt for a fuel pump or clutch - I'm an adult . There is more HP and TQ to be had if you go this way and if you do...get the clutch.
Mileage today after 1/4 city and 3/4 tank of highway driving was 28.6MPG. I'm halfway through the next tank and the avg on the meter is 31.4 so I'm thinking I should be around 30+MPG or close to it on the highway. What does this mean...? I've lost .5 - 1 MPG maybe being boosted. In other words I've got over 100HP extra and it costs me little to nothing as a DD.
You guys wanna here some crazy chit? The car pulled 33MPG with all hwy driving!!! Now this isn't to say that I never had my foot in it but it was 98% hwy with a couple of "spirited" passes and 3 or 4 city fly-by's. This thing is starting to loosen up and settle in.
Hesitations about buying this kit or service from PTuning...? NONE - All first class
PTUNING is offline
Old 10-27-2010, 08:00 PM
brett561tc's Avatar
that seems like a more realistic baseline than some other ones out there. btw there is a 2nd get tc fi forum now.
brett561tc is offline
Old 10-27-2010, 08:04 PM
MeatRocket's Avatar
watching
MeatRocket is offline
Old 10-27-2010, 08:09 PM
PTUNING's Avatar
By any chance do you remember what the other baseline number was?
Was it a shop or just an individual?
We just want a solid baseline number before product development on the tC2.
PTUNING is offline
Old 10-27-2010, 08:13 PM
brett561tc's Avatar
https://www.scionlife.com/forums/sho...d.php?t=194751
Old 10-27-2010, 08:15 PM
brett561tc's Avatar
just noticed the heat shield on the underside of the hood. is that stock?
Old 10-27-2010, 08:19 PM
PTUNING's Avatar
Thank you.
Wowser! The window sticker on the car only show 180HP.
So, we figure 159WHP on our dyno was dead on.
PTUNING is offline
PTUNING's Avatar
Yes it is.
PTUNING is offline
Old 10-27-2010, 08:22 PM
brett561tc's Avatar
Yes it is.
Now that I like. Guess Scion realized that people like boosting tC's.
__________________
Old 10-27-2010, 08:49 PM
PTUNING's Avatar
now that i like. guess scion realized that people like boosting tc's.
Unfortunately, If you were to boost the tC2, the shield would have been more effective installed towards the driver-side.
PTUNING is offline
Old 10-27-2010, 08:50 PM
Syldrin's Avatar
what would the numbers come out to be on a dyno jet? isnt that what church's uses?
Syldrin is offline
Old 10-27-2010, 08:56 PM
Rob_DESCENDANT's Avatar
Chruch's Automotive uses a DYNOPAK
Rob_DESCENDANT is offline
Old 10-27-2010, 09:00 PM
Ronin Scion
Ace83's Avatar
churches uses dynapack, hub dyno.. i believe gives higher numbers coz pulls are done without the wheels. I've always been curious how it performs using other dynos like this, now i know where its power really stands
Ace83 is offline
Old 10-27-2010, 09:03 PM
Jon
Moderator
Moderator
Jon's Avatar
These numbers seem a lot more realistic.
Jon is offline
Old 10-27-2010, 09:09 PM
TCpete's Avatar
they are... i raced one of those the other day and completely destroyed it... and my car currently isn't even 100% FTL.
TCpete is offline
Old 10-27-2010, 09:12 PM
AdmirN's Avatar
Deff. watching to see the turbo kit
AdmirN is offline
Old 10-27-2010, 10:57 PM
user 7208230's Avatar
Rob It was awesome to meet you last night at Knott's Scion Night. You showed me around the tC2 towards closing time right before Chris Rado was looking at it. I was the guy with the fro, must have been about 7:15p.
Pretty impressive baseline that you pulled of ~197hp and the setup that you're coming out with is insane! 333hp...sik. Definitely would want a ride in that thing. Keep up the good work!
user 7208230 is offline
Old 10-27-2010, 11:01 PM
djshway's Avatar
Defintly going to be watching this.
And as for the the dyno numbers Ptuning got, i would have to agree with everybody that it seems realistic. although, curious how the other numbers are so hi? Is it really a difference between those two types of dynos?
djshway is offline
Old 10-27-2010, 11:37 PM
stevejohns29's Avatar
subscribed.
stevejohns29 is offline
Old 10-27-2010, 11:53 PM
Ronin Scion
Ace83's Avatar
the other dyno is closer to crank numbers, the dyno is connected to the wheel hubs and the car runs lighter without the wheels.. still those are legit numbers used as a tuning tool.. but imo doesnt represent the actual hp wheels put on the ground
Ace83 is offline
Quick Reply: PTUNING: 2011 Scion tC Turbo Kit (Available to ship)
