Scion tC 2G ICE & Interior In-car entertainment and electronics...
Back Up Camera tC2+
Old 11-17-2015, 11:21 PM
bhouck04's Avatar
Default Back Up Camera tC2+
Hello,
I am trying to figure out to install a back up camera for my 2015 tC. Anyone ever install one? If so, what exactly do I need to get to be able to install it?
I have been searching for two days and i cannot find anyone talking about what exactly they used and if it was possible. Much appreciated to anyone who can help.
-Bill
bhouck04 is offline
Old 11-18-2015, 10:48 PM
Rydrdg's Avatar
Rydrdg is offline
Old 11-18-2015, 10:49 PM
Rydrdg's Avatar
Amazon.com: 2014-15 Scion Backup Camera Kit - Plug and Play for Display Audio Radios!: Automotive Amazon.com: 2014-15 Scion Backup Camera Kit - Plug and Play for Display Audio Radios!: Automotive
Rydrdg is offline
Old 11-19-2015, 06:15 PM
kfunluc's Avatar
I think this is what you're looking for. I'm waiting to pull the trigger on this kit as well!
https://camera-source.com/scion-disp...amera-kit.html
kfunluc is offline
Old 01-01-2016, 02:18 AM
15sciontcblizzardbearl's Avatar
I just did this today using the camera source kit. Easy to set up, it's the running of the wire that's a _____. Took me half of day with some breaks. Enjoying it so far!
15sciontcblizzardbearl is offline
Old 01-05-2016, 02:00 AM
Freevegan's Avatar
can you post some photos?.. or video? id love to see..
Freevegan is offline
Old 01-05-2016, 02:16 AM
definitely. what are you looking for? just what it looks like on car, on dash? I can take some tomorrow when it's light out.
Old 01-05-2016, 02:27 AM
Freevegan's Avatar
(also.. i have a 2016 Scion tC Pearl White =]] )
photo of how the back up camera looks near the license plate, (from close and a bit behind) see how noticeable it looks.
and yes, a few of inside of the dash when its in reverse mode.. thanks for this, i just got a 2016 Scion tC and i been actually thinking of getting this.
Old 01-05-2016, 09:31 PM
Car twins! I'm loving the white to be honest. I've always had dark cars and actually wanted a black tC. I'm actually glad they only had white and gave me a good deal to take the white.
Anyways, here are the pictures and a video. I don't know how to post pictures on the forum so I uploaded them to a photobucket account and left some comments on each one. Pictures and Video
My only complaint is that the camera is useless at night. Can't see anything behind you with it. Not enough light from the tail lights to make it useful.
Let me know if you have any other questions. Happy to help.
Old 01-06-2016, 05:45 AM
Freevegan's Avatar
its funny cause i was either going to pick the black or the white tC, and i fell in love with the pearl white and said 400$ isnt nothing over 5 year term.
not happy hearing that its useless at night.. thats one of the main reasons i want it, especially cause at work i reverse into my parking spot and its still dark haha.
but thank you a lot for all the photos/video.. i seen it.. can you tell me where you ran your wiring? also thanks a lot!!
Old 01-07-2016, 12:37 AM
its funny cause i was either going to pick the black or the white tc, and i fell in love with the pearl white and said 400$ isnt nothing over 5 year term.
Here are two pics of the camera at night. I guess it's not terrible if you're in a lighted parking lot. Out of driveway it's useless but I also have a dark driveway. You can be the judge!
As far as the wire goes, I started behind the radio, went under the steering wheel down the to the plastic piece near the driver side door. If you pop that up, all your wires are run down it. I snapped it into place with others, came up the seatbealt plastic to the plastic molding/carpet on the roof, I cut across to the middle of the car to find the rubber leading into the trunk then tried to go through that rubber (I couldn't do it). Once in the trunk, I removed the plastic all around and ran the wire around the trunk through the newly drilled hole. I used zip ties in the trunk to hold it with other wires.
I'll post a video tomorrow, meant to get one today but had a meeting after work. But wanted to at least give you an idea. Running the wire, as a I said, was the most time consuming and frustrating parts. It took me a while to get the best path to where I wanted to go.
Old 01-12-2016, 03:55 PM
johnnya005's Avatar
I purchased a 2016 tC last night and didn't even realize there was no rear view camera. While I am no expert by any means, I am fairly certain you don't need to spend $150 on those connections to install a rear camera. You should be able to add a few connections to the factory wiring. I actually did this to my 2013 Corolla with a factory display radio and it worked fine. If you're not in a hurry and if no one has posted how to do this, I can post in the near future. You can actually go search at the toyotanation forum and look under 10th gen Corolla section and you should be able to find what I'm talking about. Most of these radios share the same wiring.
johnnya005 is offline
Old 01-12-2016, 03:59 PM
Originally Posted by johnnya005
I purchased a 2016 TC last night and didn't even realize there was no rear view camera. While I am no expert by any means, I am fairly certain you don't need to spend $150 on those connections to install a rear camera. You should be able to add a few connections to the factory wiring. I actually did this to my 2013 Corolla with a factory display radio and it worked fine. If you're not in a hurry and if no one has posted how to do this, I can post in the near future. You can actually go search at the toyotanation forum and look under 10th gen Corolla section and you should be able to find what I'm talking about. Most of these radios share the same wiring.
For me the $150 was worth for the sole factor of not having to splice into any wires and basically having everything I need for it to work. Yes it can be done cheaper but this kit was literally plug and play. I recently did one on a ford where we had to find reverse wires in the kick plates and tap into the reverse tail light. Comparing my install to theirs Mine was much easier because it was all right there. Yeah you save a few bucks by other ways but for convience this worked for me.
Old 01-12-2016, 04:12 PM
johnnya005's Avatar
For me the $150 was worth for the sole factor of not having to splice into any wires and basically having everything I need for it to work. Yes it can be done cheaper but this kit was literally plug and play. I recently did one on a ford where we had to find reverse wires in the kick plates and tap into the reverse tail light. Comparing my install to theirs Mine was much easier because it was all right there. Yeah you save a few bucks by other ways but for convenience this worked for me.
Not disagreeing with you, but the process was simple. There were only 4 wires that you needed to connect with the exception of the reverse wire. I'm not sure if that wire is already hooked up in the Scion. On my Corolla, the wire was already there.
Old 01-13-2016, 04:01 AM
SoKrispy's Avatar
Splicing into reverse lights is one option.
I have mine spliced to 12V cigarette lighter.
This enables you to turn on the camera regardless of what gear you're in.
SoKrispy is offline
Old 02-01-2016, 08:07 PM
johnnya005's Avatar
After spending some time looking into this, the 2016 radio appears to have a different connector for the video source. I have been unable to find the proper connection/harness to make this work. Here is a picture of my radio. Are you able to post close up pictures of your radio (front and back)? BTW, I see that $150 harness goes for $20 (china made) on ebay. Same connector/wires.
Attached Thumbnails Back Up Camera tC2+-img_0254.jpg   Back Up Camera tC2+-img_0251.jpg
Old 02-07-2016, 10:45 PM
Freevegan's Avatar
im glad you found this out before me.. i own a 2016 also
Old 03-04-2016, 05:27 PM
Daica's Avatar
I also have a 2016 tC and have been thinking about installing back up camera as well. Has anyone able to do it with the new radio? could you maybe post some of the things you bought?
Daica is offline
Old 03-04-2016, 07:00 PM
johnnya005's Avatar
The 2016 FR-S has the connector we need to enable the rear camera feature. That connector is not present on our 2016 tCs. Need to get my hands on one of those, but not sure how. The dealer was not much help as they could not see the individual connectors.
Old 03-11-2016, 12:25 AM
tC_toph's Avatar
Camera install looks good, just a heads up you can get the trunk lift handle thing + painted from trdsparks for a little over $100, I messed mine up a tiny bit when pulling the emblem off with a heat gun..
http://www.sparksparts.com/auto-parts/2015/scion/tc/base-trim/2-5l-l4-gas-engine/body-cat/exterior-trim-lift-gate-scat
tC_toph is offline
Quick Reply: Back Up Camera tC2+
