DIY: Stopping rattle in drivers door.
#41
I have a case number with scion corporate and I'm supposed to take it to the dealership to get it checked out but my local dealership is packed all the time so I don't know when I'll have the chance to take it in to get it checked out.
#42
If it's the vibration in the doors, use silicon to reduce or maybe even stop it. I took out the switches and put silicon around it and now there's no more vibrations. I did this for both doors. I have the base pioneer unit. Settings are on xB or xD I don't remember. Treble 5, bass 0. I hope this helped somehow.
#43
How can I fix the rattling doors?
I swear everytime the bass in a song kicks, all I hear is my doors going crazy, I feel like it is gonna come off. I didn't care for them at first, but this girl sat in my car, and she actually said "what is wrong with your doors?" and that really got to me. I don't know why! haha, I found out if you put your hand on the window and lock buttons when your listening to a song, it doesn't make the rattle noise, I'm sure this is with all TC2's because my friends does it as well. Is there a solution for this? or do I have to stick toilet papers in there to stop the noise.
#44
WellesleyScion posted a fix for that about a year ago. Basically you're correct. Pop off the plastic piece that holds the window controls, fold up a piece of paper and put it on the lip closest to the middle of the car. Stops the rattling almost complety.
#48
You pop the panel up from the rear. I used a screwdriver and carefully pried the panel up near where the arm rest is. The front has the retaining clips, so you can't pull the panel up near the door handle.
Also, I found the link to the original post. I was hoping it had pictures, but not so much. DIY: Stopping rattle in drivers door
#49
#51
3m sells this tar like substance that works alot better it doesnt run when hot or anything but you only need a tiny bit of it its very stretchy and you just stretch it and run it around its sticky so it will hold itself in place and yet comes off when you need to re remove the panel
#52
I don't know, I'm kind of sketched out about this. The link says that there is like 3 people who broke the panels, and now it even rattles more. Has anyone tried calling scion about this? see if it's covered by the warranty? it's a quick fix, but if they mess it up then it's their fault lol.
#54
Like I've said before in other posts, the first time you pop the panel is the worst.
It sounds and feels like it is going to break... but most-likely, it wont.
I doubt the dealership will fix it... if they even agree to give it a try.
#55
I was just at the dealer for the 5k service. I had reported the the window control switch vibrates when the volume is up, but they said there was nothing they could. I even told them how I've read that other dealerships have used "silencing kits" to fix it, or so I've read somewhere else on here.
So they bring my car out to me and it's all wet. I'm like why is it all wet? They tell me they run it through their automatic washer. So now I'm ____ed because I just paid to have the car washed the day before professionally, they run it through their sprinkler and don't even have the decency to dry it off.
I drive off and get a block away and realize they didn't even turn off the maintenance required light.
#56
Just posted this in another thread:
#58
Ok fine here's some pics of what I did... I am not sure if the paper is in the right location but it seems to work for me. And the paper hasn't fallen out yet and I did this weeks ago.
Pull from bottom, and slide towards back:
Top Clip. DO NOT PULL FROM THIS SIDE!
Fold and put paper here:
Slap it all back on...
That wasn't so hard was it?
#60
Finally got around to doing this after over a year of listening to the rattling. Used several layers of masking tape around the edges. The panel now pops on snugger than it did before and I hear no rattling. Thank goodness.
