Disassembling tc2 center console
havnt done it yet, but that panel to the right, that starts in front of cupholders, and that wraps around the passenger side of the console, pop it up right there on the left edge of it at the very bottom of your picture. the entire top edge edge of it unclips, all the way around the side of the console, then the bottom edge parallel to the floor on the passenger side of the console is kinda on a hinge of sorts, and when its all unclipped on the top, itll kinda open i guess youd say on those hinges towards the passenger side, opening up all that space in console so that should be a good start and be able to see if there is any screws or anything holding the other pieces in
if that confuses the hell out of you (not the best at explaining with words) i can take pics and show you
Pull on the parts of the center console like you see in the pictures. Once you get the front piece off, you should be able to pull off the parts you want. Just be careful you don't break the wires when you pull off the front piece. And the first panel panel you pull needs to go on just like it came off. There are plastic clips you don't want to break.
Lego cars... I'm impressed so far with mine, removed entire interior with only 2 socket wrenches, haven't broken one plactic clip or anything and it goes back together exactly the same as I took it apart flawlessly! Can't say the same thing for other cars I have owned...
Nerdcore314
05-01-2015 11:54 PM
