Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Brake help
Old 08-01-2014, 04:04 AM
wrelkin123's Avatar
Unhappy Brake help
dont know if this is the right category but i need help, i was painting brakes on my 2012 scion tc and screwed up, what are the torque specs for the bracket and caliper, and i lost the little rubber washer around 1 caliper slide pin what does it do, i also mixed up which pin with the little rubber gasket goes, is it the top or bottom slide pin, one caliper bolt flew off i need to get a replacement and tighten..
wrelkin123 is offline
Old 08-04-2014, 09:10 PM
FlintMica17's Avatar
42 ft. lb. for both. If you are referring to the rubber o-rings on the ends of the slides, it is there to absorb vibrations (which make noise). Both slides should have the rubber insulators on the ends, as well as the rubber dust boots.
FlintMica17 is offline
Old 08-05-2014, 10:32 PM
wrelkin123's Avatar
Wait really only my bottom ones had the rubber gasket at the end of the slide, where would I get replacements, and 42 for both the caliper and bracket?
Old 08-07-2014, 02:53 PM
Just checked and yes, just the lower bolts have the rubber insulators. I apologize for giving out the wrong info man. I can't find a torque spec for the caliper slide bolts, just the brackets. Slide bolts don't need to be extremely tight, somewhere in the 25-30 ft. lb. range would be just fine.
gqdabien
10-08-2015 05:36 PM
Klashan
09-24-2015 12:39 PM
DannyBoy65
09-21-2015 06:23 PM
axB
09-18-2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
09-14-2015 12:39 PM
Quick Reply: Brake help
