Wheel and tire question
Old 06-21-2014, 06:48 PM
2011TC2's Avatar
Default Wheel and tire question
Hey guys I'm new here. I currently have a 2011 Scion TC and was thinking about getting new wheels. I'm thinking of getting 18x8.5 wheels and 245/40 tires. I called the tire shop and some guy told me 245's won't fit and will rub a lot. Does anyone know if that's true?
2011TC2 is offline
Old 06-22-2014, 12:10 AM
KILLER's Avatar
They wont run even if you have Eibach sportline springs. Just remember that at some point you will either have something heavy in your hatch or 3 people sitting in the back seat and that will cause the tire to rub.
KILLER is offline
Old 06-22-2014, 01:12 AM
G5_TC's Avatar
those wont rub at all.. maybe like said above (if you have people in the back) but i would go with 245/35 tire.. (my current set up is 19x8 245/35 and i have zero rub.)
G5_TC is offline
Old 06-22-2014, 02:24 AM
2011TC2's Avatar
So the guy at the tire shop doesn't know what he's talking about? haha
I'm fairly new to modding and I'm stilling learning but why would a 245/40 rub and 225/45 won't?
2011TC2 is offline
Old 06-22-2014, 02:44 AM
HOODedDutchman's Avatar
I don't see why they would rub at all. The 245/40 should have a slightly (3mm) lower profile than the stock 225/45. Unless your running a really low offset wheel there is no reason why it would rub. I don't think I'd go with a 35 sidewall on an 18. Won't look right. That's over 15 mm smaller sidewall.
HOODedDutchman is offline
Old 06-22-2014, 02:50 AM
It's not going to rub anyways. 8.5 wheel is 1" wider than stock. 245 is only 2 cm or 20mm wider than stock. So the tire will be slightly more stretched than stock tire size on stock rim. I'd say it's perfect for that rim size. Just be careful what offset the wheel you purchase is. That is the only thing that could cause rub.
Old 06-22-2014, 03:10 AM
G5_TC's Avatar
i like to always refer to my fav website http://www.rimsntires.com/specspro.jsp
you can compare what your tire is now (the left) to what you want next (the right)
you get pretty good mesurements.
G5_TC is offline
Old 06-22-2014, 03:24 AM
2011TC2's Avatar
Thanks for all the input guys. I'm still learning haha.
This is my plan so far. 18x8.5 +38 on 245/40 all around. Will there be rubbing or would I have to roll the fender or anything?
Any specific tires you guys recommend?
2011TC2 is offline
Old 06-22-2014, 04:20 AM
2011TC2's Avatar
Also do you guys know the bolt pattern for 2011 TC is? I looked it up and found 5x114.3 and 5x100. Idk which one is right haha
2011TC2 is offline
Old 06-22-2014, 04:42 AM
G5_TC's Avatar
i think you will be fine, no rubbing or needing fender roll. since your at stock hight right? TC2 bolt pattern is 5x114.3 TC1 is 5x100 i think i would get a 245/35 tire it wont look as bulky but im not sure what you want for look.
G5_TC is offline
Old 06-22-2014, 05:00 AM
2011TC2's Avatar
Ok thanks. Yeah it's stock height. The look I'm going for is more of the standard look not the "slammed" look.
Idk why the guy at the tire shop saying it will rub big time and told me to get 235's instead haha
2011TC2 is offline
Old 06-22-2014, 11:05 PM
yardleyTC's Avatar
out of curiousity. why are you getting a 245/40. i have a 18x9 rim on a 225/40. fits fine. rides fine and would be very safe from rubbing
yardleyTC is offline
Old 06-23-2014, 01:10 AM
Isn't that the point in getting a wider rim. Getting a wider tire. Not only do you get wider stance but you also get more tire on the ground with a 245. If you have a 225 on a wider wheel it's still the same amount of tread touching the road. So u only get the stance. Not the grip.
Old 06-23-2014, 02:17 AM
2011TC2's Avatar
I want to get wider tires cause I think it would look better haha. If I lower it will it rub for sure or nah?
2011TC2 is offline
Old 06-23-2014, 02:24 PM
DaYUUM/Scion Evolution
KidJustin's Avatar
the tire guy might have said that to give u a "scary" reason to not get 245...cause on a 8.5 wide wheel, 235 is the common tire width for that wheel width and looks the best. 245 might get bulky (the wheel i'm selling is 8.5 width with a 235 tire if u want a reference)
tyrestretch.com is a good source to what a certain tire spec looks on a certain wheel spec
also 40 or 45 sidewall is best for an 18", 35 is more for a 19"
KidJustin is offline
Old 06-23-2014, 05:04 PM
2011TC2's Avatar
Oh ok. Do you have a picture of it so I can get an idea of what it looks like? Will 245 be too wide and give it that "slammed" look when I'm trying to keep the standard look?
2011TC2 is offline
Old 06-25-2014, 02:41 PM
KidJustin's Avatar
the link i provided has oogles of pictures. and i said you can find pictures of a 8.5 wheels with 235 in my thread (personal or sale)
tire width has little to do with "slammed" look since "slamming" a car means going lower. the wider the wheel or tire could potentially rub the inner fender depending on how low it is, but there a billion other factors that could be done to adjust and avoid that
Old 06-26-2014, 02:24 AM
2011TC2's Avatar
Ok thanks. I now have an idea what they look like.
Do you have any tire brands that you recommend?
2011TC2 is offline
Old 06-26-2014, 02:37 AM
2011TC2's Avatar
Also does hub bores matter when buying new wheels?
2011TC2 is offline
Old 06-26-2014, 04:01 PM
KidJustin's Avatar
Falken, Hancook, Nitto
buy hub rings they are cheap. go plastic instead of aluminum
Quick Reply: Wheel and tire question
