DIY Rear Wheel Bearing Replacement - Scionlife.com
2004-2006.5 [NCP61]
Reply
Thread Tools Search this Thread
Old 07-27-2008, 05:46 PM   #1
Default DIY Rear Wheel Bearing Replacement
Has anyone attempted to change out a rear wheel bearing yet??
Dealer wants $300+ to replace complete hub assembly.
Noise coming from right rear, sounds like a 4x4 with 44" mud tires.
Any help would be greatly appreciated.
cncmech is offline   Reply With Quote
Old 07-27-2008, 05:58 PM   #2
It can't be that hard to replace a hub assembly, especially being a complete assembly.
How much is the part? If you have some mechanically aptitude, I bet you could do it with in a hour.
eggie is offline   Reply With Quote
Old 07-28-2008, 02:28 AM   #3
xadragon's Avatar
pretty easy to take out and put on.....did mine myself....took about 40 min tops to finish....
xadragon is offline   Reply With Quote
Old 07-28-2008, 04:14 AM   #4
cobb's Avatar
On other front wheel drive cars the front bearing is sealed and you need a press or remove the steering knuckle to get a shop to press it in. Most shops will press bearings. The rears are like the fronts of old cars with a inner and outer race, grease cap, seat and races. The hardest part would be removing and installing the large axle nut, then setting hte pre load. Prepare to get messy and to grease the bearing up, but not the brake drum or shoes.
cobb is offline   Reply With Quote
Old 07-29-2008, 12:19 AM   #5
I think that the $350 price that Toyota charges is a bit excessive!!
After all, this is meant to be an economy car, right??
I am prepared to change out the bearings myself.
I found the replacement bearings online for $26, I just dont know if they are same front to rear.
http://www.car-stuff.com/carparts/sc...-16247381.html
Where did you purchase the replacement bearings??
Old 07-29-2008, 02:23 AM   #6
Grateful11's Avatar
That bearing looks much wider than a regular sealed or shielded bearing. Almost looks like it has 2 inner races and one outer race.
Grateful11 is offline   Reply With Quote
Old 07-29-2008, 05:41 AM   #7
Team XcelsiA
SHIFT_xA's Avatar
I have seen them on ebay for around 150, but you need to get the whole assembly, it is a sealed unit and there is no way to service it.
SHIFT_xA is offline   Reply With Quote
Old 08-03-2012, 04:20 PM   #8
I just did this job about two weeks ago on my 2005 Xa that has 120,000 miles of highway driving on it in Connecticut where they use salt and some other harsh stuff to maintain the roads.
First, I paid $140+ for an OEM bearing from Amazon, it is a sealed unit with the ABS sensor in it.
I did a brake job while I was in there as well.
Finally, it took me over an hour to pound out the bearing that was rusted in there from seven years of New England winters. I put Antisieze compound on all the joints when I put it back together so it should come out easier next time if I have to do that again.
bblhed is offline   Reply With Quote
Old 08-05-2012, 03:19 AM   #9
Did you do all bearings or just the rear? I need to do my fronts had the bearings but i think ive been riding on the bad ones so long i need to replace the whole hub
Distracted_Thinker is offline   Reply With Quote
Old 08-07-2012, 08:57 PM   #10
This job is very easy. I was going to make a do it yourself for it ,but it only takes for lugs to take your wheel off and then 4 bolts to take the rear wheel bearing assembly out and an abs plug. Super ez job.
Sciota is offline   Reply With Quote
Old 10-26-2014, 02:16 AM   #11
Default very . easy job
I picked up a pair of rear wheel bearing units with the ABS plug in the back off eBay, $59.00 for the pair brand new in the box. It took about 30 mins a side to change them, car sounds like New.
The Toyota dealer wanted $1300 to do the job. One of the most profitable hours I have spent in a long time.
Started making noise at 145k BTW.
Mike
bykemike is offline   Reply With Quote
Old 01-19-2015, 03:44 AM   #12
SatsumaxA's Avatar
Mike
DITTO: EBAY FTW/TOOK 30MIN/SIDE..WITH FLOOR JACK IN FRONT YARD
MAJOR DIFFERENCE IN ROAD/WHEEL NOISE!!!!!
SatsumaxA is offline   Reply With Quote
Old 12-31-2016, 03:27 PM   #13
ironman3452's Avatar
not too bad, take wheel off, remove caliper holder, remove rotor, remove 4 bolts on back, remove the abs clip on the back of the bearing, replace the same as you took a part
ironman3452 is offline   Reply With Quote
Old 12-31-2016, 03:31 PM   #14
hey cobb what are you working on?
Reply
Thread Thread Starter Forum Replies Last Post
Drivers front vibration above 45 mph that changes with steering input fur_pig Scion tC 1G Suspension & Handling 6 01-26-2015 05:26 AM
Good wheel bearing brands for replacement??? xdejablu3x Scion tC 1G Suspension & Handling 2 12-28-2014 03:44 AM
2008 scion tC won't start.. Jordly221 Scion tC 1G Owners Lounge 2 12-03-2014 06:09 PM
manual trans zom6iemac Scion xB 1st-Gen Owners Lounge 1 11-28-2014 01:28 PM
2010 Scion XB got it royaly Joeynenj Scion xB 2nd-Gen Aero & Exterior 3 11-25-2014 06:29 AM
Tags
510, axle, bearing, change, datsun, diy, front, honda, insight, rear, replacement, scion, wheel, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
