2005 xA vs. 2008 Yaris Engine Transmission Swap questions
Ok, got the trans mount in, dealer typed in wrong PN and sent me another xA fuel hose instead of a Yaris part.......... So hopefully correct part will arrive by tomorrow and we'll see from there.
**UPDATE**
Got fuel hose from dealer, realized that I needed to get a Yaris retention clip for the fuelhose to fuel rail junction... Luckily I was able to get one from the junkyard ... Put it all together and fired it up. The car ran fine, no hiccups yet...
Update, just because...
Swap completed in late September of 2010.
Car is still running. Drove it Boston to Orlando and back in December of 2010, been driving it daily ever since. Engine still running fine. And yes, I stay on top of checking the oil!
A) replace 4th w/ 5th and find a gear with a ratio about 0.67 (guessing)
B) add a 6th gear as an overdrive
It's also a little less wear on the engine to run lower RPMs at higher speeds. That's why most vehicles have an overdrive. Engine life and fuel consumption.
Didn't end up using Yaris trans. Stuck with xA trans due to mounts not being the same.
Yaris engine still going. Car is about to hit 210,000. Yaris engine went in at 10,000 with 143,000 on the car. So Yaris engine is just about 77,000 currently.
I didn't have a lift. I took the engine out through the top and put the replacement in through the top with the trans still in place. I loosened the K member a lot to get enough room to mate the two. To anyone who loosens the K member, be careful! The steering wheel can become free to turn and break the clock spring. I forget the details because it has been years. I am about to loosen the K member to replace the transmission. At least my clock spring is already broken this time :/
cid_mcdp
01-05-2015 02:45 PM
