2005 xB overheating
Old 08-28-2016, 05:02 PM
petshack's Avatar
Default 2005 xB overheating
Ok
No one can seem to figure this out around my town
Only overheats when driving more then 20 Miles and ac on
Water comes out of reserve tank
Takes about gallon to fill back up
Drove 45 min on hwy with ac ran fine coming back 2o min into trip hot light blinks I turn ac off put on heat light goes off , put on ac comes on again
New #1 fan relay
Radiator cap
Water pump
Pcv valve
Thermostat
Flushed radiator
No leaks
50/50 running
Plugs
new points / plug wires
Head gasket checked and fine
Never see any leaks
Oil clean no water
Any ideas
And do I have one fan or two I saw relays #1 replaced not #2
This is 2nd engine in car
Last one I ran hot and blew ( of course) this engine has 75 ,000 on it
New brain I car when engine went took it along with it also new transmission modules (3)
I have done the easy stuff myself the other I take to machanic
Thank you
Again only when ac is on and 20 min of driving
petshack is offline
Old 08-29-2016, 01:22 PM
HATEnFATE's Avatar
When you're sitting at an idle and you turn on the A/C....what happens to the engine idle speed? lights dim? Rough running?
HATEnFATE is offline
Old 08-30-2016, 03:58 PM
petshack's Avatar
Default Idle
It runs smooth
If I turn ac off it will idle rough
I think I did see lights dim
petshack is offline
Old 08-30-2016, 05:05 PM
HATEnFATE's Avatar
Hmm...I was thinking too much drag on the engine front a seizing pump, but that doesn't sound like the case...
Old 08-30-2016, 05:08 PM
petshack's Avatar
I made appointment at dealership before I blow this motor put one in 2 yrs ago
Sitting here at idle ac on runs idles great , then rough then back to normal again then rough
Turn ac off same idles rough, ac on normal again
petshack is offline
Old 08-30-2016, 05:14 PM
HATEnFATE's Avatar
Wild curvball here......
Is your radiator or condensor mildly clogged maybe? Not internally, but externally?
When you're moving, the clog isn't allowing enough airflow to make it through the radiator and the extra load and small amount of added heat from the A/C condensor are are making the conditions just right to allow the car to overheat??
Old 08-30-2016, 05:15 PM
HATEnFATE's Avatar
have you confirmed that the fan is actually turning on?
Old 08-30-2016, 05:16 PM
petshack's Avatar
Had radiator flushed 2xs
Not sure about other
petshack is offline
Old 08-30-2016, 05:17 PM
petshack's Avatar
That sounds like what's going on
Now how do I or dose this have to be professionally done
petshack is offline
Old 08-30-2016, 05:22 PM
HATEnFATE's Avatar
Just look through your grille and see if there's a bunch of debris jammed in the cooling fins of the condenser, and look in the engine compartment and do the same thing both behind the radiator, and between the two..
Any confimation on the cooling fan engagment? typically, on a dual fan car the A/C fan turns on as soon as you activate the a/c. I haven't checked to see if our b's do the same thing as they are a single fan system.
P.S. make sure the large plastic baffle/plate is there to the right of the radiator/condenser. it forces air through the two instead of going around them...
Old 08-30-2016, 05:25 PM
petshack's Avatar
Any confimation on the cooling fan engagment? typically, on a dual fan car the A/C fan turns on as soon as you activate the a/c. I haven't check to see if our b's do the same thing....
Yep checked nothing blocking either
Ac very cold
I changed only #1 fan relay think I need to replace fan #2 relay
Same relay works same fan which I thought was odd
I only see one fan though
petshack is offline
petshack's Avatar
Yes fan is going on
petshack is offline
Old 08-30-2016, 05:29 PM
petshack's Avatar
Not sure what this is
Only clear plastic is the fan box thingy
Nothing on left side open to grill
petshack is offline
Old 08-30-2016, 05:43 PM
HATEnFATE's Avatar
this thing. it forces air to go through the radiator and condenser...
Old 08-30-2016, 07:50 PM
petshack's Avatar
Yes I see fan running
I pull #1 or #2 relay it stops
petshack is offline
Old 08-30-2016, 07:51 PM
petshack's Avatar
I don't see that in mine
petshack is offline
Old 08-30-2016, 09:14 PM
HATEnFATE's Avatar
Can you PM me your VIN so I can get some info on your xB?
Old 08-30-2016, 10:21 PM
HATEnFATE's Avatar
Here are pics of my 06. Should look like this. If not, that might be part of the prob..
ucity5
07-28-2016 05:50 PM
bgang
06-26-2016 02:29 AM
Bobakiss
Scion xD ICE & Interior
03-30-2016 05:18 PM
ChicagoScionFistingClub
12-31-2004 09:10 PM
Quick Reply: 2005 xB overheating
