AEM cai with K&N filter?
Old 03-26-2007, 03:48 PM
Straylight's Avatar
Default AEM cai with K&N filter?
Hey folks, I've done some searches and I haven't been able to find the answer to my question, so if I'm asking something that's already been answered, I apologize in advance.
I have an AEM CAI that was installed by the dealer on my RS2 XB. (Powdercoated yellow)
I am wanting to swap the AEM air filter on it for a new K&N... Does anyone know what K&N part will fit this CAI?
Thanks!
Straylight is offline
Old 03-26-2007, 07:28 PM
DriverXa's Avatar
why not use the aem dryflow filter. All u have to do is use the special cleaner to clean the filter and let it dry, thats it. No need to mess with re-oiling the filter and running a risk of overoiling it and f'n up ur maf sensor.
DriverXa is offline
Old 03-26-2007, 10:17 PM
Straylight's Avatar
I completely understand. I still want to know what K&N filter will fit on it.
Old 03-26-2007, 11:22 PM
jct
jct's Avatar
messure the OD of the intake pipe and use that as the ID of the K&N air filter simple as that
jct is offline
Old 03-27-2007, 04:11 AM
TheShortBus's Avatar
Default AEM CAI PDQ ASAP FYI
StrayLight,
I just R&R'd my AEM intake filter (at 45k miles), and was interested--like you--in other replacement options for filters. I measured the INSIDE diameter of the rubber flange at the BOTTOM of the AEM filter and believe it was 2.25". Pretty sure if you look it should be molded into that rubber bottom part.
In any event, I tried contacting dealers for several other brands and nobody came up with a filter having a 2.25" ID bottom. Maybe contact K&N direct and see what they suggest. (It's even possible that the AEM filter is made for them by K&N?) Anyway, good luck!
TheShortBus is offline
Old 03-27-2007, 05:38 AM
OldYeller's Avatar
special cleaner--I must have missed that one--please enlighten.........
OldYeller is offline
Old 03-27-2007, 04:29 PM
DriverXa's Avatar
^ All of these reuseable filters use a kit that u buy seperately that includes a cleaner and the oil to recharge the filter. Basically spray the outside of the filter with the cleaner, let it set for the recommended time, then u wash it from the inside out and all the dirt and oil will come off. Then u must let the filter air dry this is important as using a hair dryer or something will mess up the filter. The filter will be completely white, then u either spray or pour the oil onto the dry filter very sparingly. The color in the oil shows u where u missed so apply very little oil untill it gets the color of the oil(TRD is a yellowish color, K&N is red, Fram AirHog is Orange, etc.) The problem with this is that since most people its their first time or whatever apply too much oil which after u let the filter dry out u can feel the excess. This excess gets sucked up into the intake and ruins ur maf sensor causing the car to run like crap.
Now with the AEM dryflow filter all u have to do is apply cleaner and do the same process of cleaning from the inside out, let it dry, and reinstall. That's it, no oil to mess with. The reason is is that the AEM uses synthetic materials unlike the oiled fileter which are made up of layers of cotton. The AEM will not break down and is water resistent, plus since its not cotton and there is no oil to mess with it takes significantly less time to do a cleaning session. I had a AirHog on my last car and although it did performe very well the hassle of cleaning and oiling it was a PIA. This new filter is what I'll be putting on my xa when I get my cai even though u get a new filter with it. Just sell it on ebay and offset cost of AEM.
DriverXa is offline
Old 03-27-2007, 10:03 PM
xA_Factor's Avatar
The diameter is 2.25 inches.
BTW, if you decide to go with the DryFlow filter, the part # is 21-200DK.
The first thing I did before install my TRD CAI was to dump the oiled filter for a DF filter.
xA_Factor is offline
Old 03-28-2007, 06:13 PM
Straylight's Avatar
Thanks all for the responses. I think it's pretty odd that K&N wouldn't have a part that fits this (in a cross reference chart or something) since they have so many 'universal' designs.
I was looking for a K&N solution simply out of brand loyalty - on pretty much every other car I've had all the way back to the mid 80s, I've had a K&N filter equipped and never have had any issues.
Old 03-28-2007, 06:16 PM
OldYeller's Avatar
hey---thanks--I see what you mean from the AEM website-------
steeze69
05-24-2021 02:57 AM
MeDizzy
10-08-2015 03:31 PM
Nkelly
09-07-2015 05:06 PM
Threequalseven
08-26-2015 04:24 PM
stenger
07-15-2015 01:03 AM
Quick Reply: AEM cai with K&N filter?
