CEL P0504 P0124 and "hiccup" under accel
Hello all,
I have a 2006 Scion XA that has about 220,000 miles on it (owned since new). It has been a good car. I've had a check engine light for the last 2 years. I was in a small accident last month all things have been repaired exterior wise. They replaced the catalytic converter and O2 sensor also. All codes went away for about 3 days. The car has been recently "bucking" or "hiccuping" while under acceleration. Doesn't stall, just feels like it loses power. It's done this for about a year may or may not be related to the CEL codes listed:
P0504, P3e04, P3f24, P0124, P0224, P1900.
All codes were read with a OBDII scanner (cheap, but has worked in the past).
Any ideas on what the codes/problem could mean?
Thanks!
Thanks!
but the last one i replaced ..... the 5th one now it seams like it went to having something else went bad...... think its the computer or the wiring harness because it seams to misfire on the first cylinder no mater if i switch the fuel injector or put a new spark-plug in or a new ignition coil
xb4lf
04-04-2015 07:15 PM
