CEL P0504 P0124 and "hiccup" under accel
Old 05-04-2014, 03:53 PM
bce181's Avatar
Default CEL P0504 P0124 and "hiccup" under accel
Hello all,
I have a 2006 Scion XA that has about 220,000 miles on it (owned since new). It has been a good car. I've had a check engine light for the last 2 years. I was in a small accident last month all things have been repaired exterior wise. They replaced the catalytic converter and O2 sensor also. All codes went away for about 3 days. The car has been recently "bucking" or "hiccuping" while under acceleration. Doesn't stall, just feels like it loses power. It's done this for about a year may or may not be related to the CEL codes listed:
P0504, P3e04, P3f24, P0124, P0224, P1900.
All codes were read with a OBDII scanner (cheap, but has worked in the past).
Any ideas on what the codes/problem could mean?
Thanks!
bce181 is offline
Old 05-05-2014, 04:58 AM
jct
jct's Avatar
have you tried to google the trouble codes yet?
jct is offline
Old 06-28-2014, 10:02 PM
finkster52's Avatar
my XA did that every time a coil went bad
finkster52 is offline
Old 06-28-2014, 10:12 PM
finkster52's Avatar
but the last one i replaced ..... the 5th one now it seams like it went to having something else went bad...... think its the computer or the wiring harness because it seams to misfire on the first cylinder no mater if i switch the fuel injector or put a new spark-plug in or a new ignition coil
MeDizzy
10-08-2015 03:31 PM
BigIrish
05-18-2015 12:04 AM
Marvelicious
05-01-2015 08:00 PM
xb4lf
04-04-2015 07:15 PM
Jmarks1998
08-24-2004 03:43 PM
Quick Reply: CEL P0504 P0124 and "hiccup" under accel
