VVTi Solenoid replacement?
Old 02-11-2012, 04:05 PM
scottbart's Avatar
Default VVTi Solenoid replacement?
When I was changing the alternator, I broke off the plastic tip of a sensor thingy just behind the alternator bolted to the cylinder head. I'm told it is the solenoid that activates the VVTi system.
There is only one bolt on the outside that holds it to the head. What else do I need to do to change it? I'm thinking that there might be more to it than just unbolting it and bolting on a new one.
____
scottbart is offline
Old 02-21-2012, 05:37 PM
vettereddie's Avatar
Nope, just unbolt, pull out and swap a new unit. Make sure the new unit has the rubber o-rings to seal it and you're good.
vettereddie is offline
Old 02-21-2012, 07:36 PM
scottbart's Avatar
Did it on Saturday. Piece of cake.
Old 02-09-2023, 06:10 PM
tbone28's Avatar
Default Two piece assembly?
Two piece assembly on my 2006. Solenoid separate. Internal parts aren’t wanting to just slide out.
tbone28 is offline
Old 02-10-2023, 08:10 AM
18TTony's Avatar
No.....these aren't two piece assemblies. If yours is in two pieces, it's broken.
The solenoid must've broken off the valve mechanism. Lots of car manufacturers have similar type valves like Toyota VVTi valves. Hyundai, Nissan, Honda, etc.....when the solenoid breaks off the valve mechanism, I may (sometimes) twist a screw into the hole in the valve mechanism and pull it out. Or maybe, (if I'm lucky) use a magnet to pull it out. .
18TTony is offline
Old 02-10-2023, 12:01 PM
tbone28's Avatar
Default Thanks
Will grab some assorted hardware at Home Depot and dig it out.
tbone28 is offline
aryana159
01-28-2011 05:44 PM
Dr_No
10-08-2007 03:30 PM
novatechKC
Scion tC 1G ICE & Interior
04-18-2007 08:14 PM
BSOhatch
12-01-2005 11:12 AM
morningman
07-04-2005 01:05 AM
Quick Reply: VVTi Solenoid replacement?
