DIY: Auto Transmission Drain and Fill (1st gen xB) - Page 2 - Scionlife.com
Reply
Thread Tools Search this Thread
Old 12-01-2010, 05:24 AM   #21
teabox's Avatar
I wouldn't know. Could possibly damage the tranny.
teabox is offline   Reply With Quote
Old 12-01-2010, 12:09 PM   #22
Noted that in the first post it said to shut the car off, then check the auto trans level.
Every automatic I have owned requires you to check the fluid level while the car is running ?
Bobb_Todd is offline   Reply With Quote
Old 01-18-2011, 05:01 AM   #23
padillaXA's Avatar
the only cars i know of that you have to check while off are hondas. everything else has got to be on.
padillaXA is offline   Reply With Quote
Old 02-14-2011, 11:24 PM   #24
So which is it engine off or engine on? I read this entire chain hoping to find the answer to that question.
ebrann is offline   Reply With Quote
Old 02-17-2011, 01:20 AM   #25
Keith's Avatar
on the auto tranny, I was told it has to be running...
Keith is offline   Reply With Quote
Old 09-11-2011, 10:47 PM   #26
I think the last time I looked at the dipstick it had a cool engine and a hot engine level. Also know that the BG flush, used at my dealership, uses chemicals to clean the sediment out of the system. I would not do the full flush after 100k if it has never been done before as I have heard horror stories of the chemicals cleaning grooves out of the trans causing huge problems afterwards.
As for Fluid type: Alldata says
DRAIN AND REFILL: 3.1 qt. (2.9 L, 2.6 Imp. qt.)
FLUID TYPE: Genuine ATF Type T-IV
Just looked up the other gen1 years and they also say 3.1 d&r however, the 04 says that a dry fill is 7.2 qts.
ToddMS is offline   Reply With Quote
Old 03-06-2013, 10:36 PM   #27
I have a 06 xa had since new never had tran or coolant serviced 106,000 what should I do
johnetrue is offline   Reply With Quote
Old 05-08-2013, 02:12 AM   #28
teabox's Avatar
For transmission, if you feel any "shock," "jump," or "shutter" when the trans is going to different gears, then its a good time to drain and fill with the 3 quarts of fluid. The point of this thread is ONLY for preventative maintance to prolong the life of the transmission.
Reply
Thread Thread Starter Forum Replies Last Post
Clutch and Motor Mount rjjablo Scion xA/xB 1st-Gen Drivetrain & Power 14 08-25-2016 01:56 AM
Gas mileage left? GoodVibes Scion xB 2nd-Gen Owners Lounge 14 12-10-2015 08:50 PM
2nd Gen hubs on 1st Gen xb? 12thhawksfan Scion xB 1st-Gen Owners Lounge 2 07-14-2015 06:18 AM
Theory on TC and poor gas mileage evolving_machine Scion tC 2G Owners Lounge 14 03-05-2015 02:49 PM
JM Auto Racing Black Friday/Cyber Monday Specials- NOW THROUGH DEC. 1ST JM Auto Racing Exclusive Sponsored Sales 14 12-19-2014 06:36 PM
Tags
auto, check, coolant, dipstick, diy, drain, fill, fluid, located, plug, radiator, scion, tranny, transmission, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
