Fuel Pump Fuel Line Removal issues..
Old 07-20-2014, 03:24 AM
rygar's Avatar
Default Fuel Pump Fuel Line Removal issues..
So I'm trying to replace the fuel pump in our 06 xB and I'm having some issues taking one of the fuel lines off. The line with the yellow clip is no problem, it's the other line.
I read this thread, https://www.scionlife.com/forums/xb-...acement-93840/ on how to remove the fuel pump and when it comes to the fuel line he says to "push the 2 tabs in, and pull, should slide off." It doesn't. I couldn't get the line to budge.
I have a few questions for anyone who's done this before. Does the clip and the line come off as one piece or is the clip supposed to stay behind? In my mind the clip separates from the hose because I've seen other fuel lines like that. Is there a special tool?
Should I just pull harder? I'm afraid to damage the fuel line if I start prying around with screwdrivers.
___
rygar is offline
Old 08-11-2014, 07:19 AM
kruso's Avatar
Then you're not pushing the two off colored tabs in far enough. The tabs come off with the fitting as one piece.
kruso is offline
Old 08-11-2014, 01:28 PM
FlintMica17's Avatar
Like Kruso said, the plastic tabs will stay in the fitting. Have you tried pushing the lines together and then pulling? You may need to do that a few times to work out any dirt that may be stopping the tabs from depressing all the way.
FlintMica17 is offline
Old 03-08-2021, 06:22 PM
Eddieh's Avatar
I know this is a old thread but it’s the only one I found that talks about the fuel pump clips. The yellow one that in the pressure line. Does it have a name or part #?
Eddieh is offline
Old 03-09-2021, 12:04 PM
mrrcom's Avatar
I think it's this Yellow clip. I was looking and I couldn't find a # for it but I found some Dorman brand universal ones that may work
Amazon Amazon
Amazon Amazon
____
mrrcom is offline
ctbzz
04-04-2017 04:10 AM
Crayola_G
01-26-2015 03:15 AM
paul_dezod
113
05-23-2011 01:25 PM
jwaggz82
19
12-08-2009 02:14 AM
proctorsilex
01-18-2009 08:01 PM
Quick Reply: Fuel Pump Fuel Line Removal issues..
