Knocking noise from engine bay? - Scionlife.com
Reply
LinkBack Thread Tools Search this Thread
Old 02-17-2010, 09:11 PM   #1
irelandsboy's Avatar
Default Knocking noise from engine bay?
I was at lunch today for about an hour, my car was running the whole time, i get back to work and when i get parked i think i hear something knocking, i turned off the radio and heater and sure enough there was a knocking noise, i pushed on the gas pedal lightly and it seemed to knock faster. I then shut it off, checked the oil, color and level looked good. I went into work for about a half hour, then came back out to the car started it up, and it's as quite as can be. Has anyone else experienced this?
irelandsboy is offline   Reply With Quote
Old 02-17-2010, 10:16 PM   #2
ilovemybox's Avatar
sounds like it needs an oil change, miles dont mean much if the car runs at idle and in-town a lot.
what oil do you use?
ilovemybox is offline   Reply With Quote
Old 02-17-2010, 10:20 PM   #3
BRUIN's Avatar
Yea i had a simiar sound i think, happened once with my mom in the car going down the free way, as soon as we exited it went away ha ha
BRUIN is offline   Reply With Quote
Old 02-18-2010, 12:18 AM   #4
ESEMRFOZZ13's Avatar
my brothers older carolla does this. after driving half hour it will start knocking and shut off, but when it cools off it sounds normal again?
ESEMRFOZZ13 is offline   Reply With Quote
Old 02-18-2010, 12:49 AM   #5
TunerKid's Avatar
is it a knock or ticking sound? ticking is normal, its the valves. if its an actual knock theres something severely wrong! how many miles do you have?
TunerKid is offline   Reply With Quote
Old 02-18-2010, 01:17 PM   #6
I just had the oil changed two months ago with 5w30 , It was a knocking noise, it wasn't the valves or injectors tapping. Thing i was thinking about, if it was serious like a rod or whatever, it shouldnt just quit knocking. I drove home last nite about 20 miles and back to work this morning with no noise, strange. i have 42,000 miles on it.
Old 02-18-2010, 06:24 PM   #7
my dad once had a platic bag and a rock up under his axle ...just saying I would jack it up and see whats to see.
cingham is offline   Reply With Quote
Old 02-20-2010, 06:11 AM   #8
Metro273's Avatar
Cheap gas perhaps?
Metro273 is offline   Reply With Quote
Old 02-22-2010, 09:09 PM   #9
'04 xB here, 35K. I have a knocking noise too. It sounds like something is banging against something else in the engine bay. It only happens when my car is in drive with my foot on the brake. It also happens only in the winter. It disappears as soon as the temperature goes above 40F.
mtxblau is offline   Reply With Quote
Old 02-24-2010, 04:17 AM   #10
I got the same knock going on now..like something is banging against the body under there...only happens if the motor is shaking like at idle or low revs pulling away sometimes..weird..
ksavage68 is offline   Reply With Quote
Old 02-24-2010, 06:26 AM   #11
padillaXA's Avatar
have you guys checked your engine mounts, is the rubber worn?
padillaXA is offline   Reply With Quote
Old 03-07-2010, 11:22 PM   #12
I had the same problem 2 of my three motor mounts were shot. Replaced the defective parts and bam problem gone!
Derfnosdod is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Airmankevin1's Project (Kim) Build Journal airmankevin1 Scion tC 1G Owners Lounge 29 07-18-2015 11:04 PM
Need new belts, not sure where to go Scionxa180 Scion xA Owners Lounge 5 03-22-2015 02:14 PM
LF TRD Supercharger Halo19boy PPC: Wanted 4 01-27-2015 11:19 PM
1NZ-FE specs eric_m Scion xA/xB 1st-Gen Drivetrain & Power 79 03-17-2013 01:21 AM
Besk one's Blue Cold Cathode Engine Compartment Mod Besk_one Scion xA/xB 1st-Gen ICE & Interior 6 11-17-2003 10:28 PM
Tags
2005, 2006, car, engine, front, knocking, noise, power, rattling, scion, shaking, shut, steering, tc, tire, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
