Manual Transmission Fluid Change - Scionlife.com
Reply
LinkBack Thread Tools Search this Thread
Old 07-22-2011, 07:40 PM   #1
Default Manual Transmission Fluid Change
I have about 108K on my 2006 Box and decided to change the trans fluid last Sunday. Everything went fine and replaced it with Royal Purple Gear Max 75W90. Wed came and I started to grind shifting from 2nd to 3rd, which has never happened before. I used exactly 2 qts, per the manual. I went ahead and picked up a few qts of Redline MT-90 and am thinking about pulling the Royal Purple out and replacing it with the MT-90 this afternoon.
Any thoughts?
Thanks all!
BrewMonkey
BrewMonkey is offline   Reply With Quote
Old 07-22-2011, 08:19 PM   #2
Carlanga's Avatar
according to the RP specs, it is on the thick side of the 90w. I'm sure ur problem becomes more obvious when initially driving rather than when she's warmed up already. Go with a thinner side of the spectrum oil like the AmsoilSynthetic Manual Transmission and Transaxle 75w-90 GL-4 (MTG) and you'll never look back. Some have had good luck with the eneos 75w-90, personally I haven't tried it but if it is thinner than what you have right now it should work as well.
Carlanga is offline   Reply With Quote
Old 07-22-2011, 08:36 PM   #3
ROCKLANDTOYOTA's Avatar
im running the MT-90 with no problems for the past 45k...
ROCKLANDTOYOTA is offline   Reply With Quote
Old 07-22-2011, 08:46 PM   #4
Actually, when I first took the box out this morning it felt notchy going into 3rd but no grind. Once she had a few miles that when I was getting a grind into 3rd. So, I would shift into 4th and skip 3rd if I could.
Just drained her and I'm going to wait a bit with a brewski. Then fill back up and see what happens. Royal Purple called me back and said they would compensate me for my "issues", and they had another report of the same situation. Additionally, O-Reilly auto parts said to bring the Royal back for a full refund and they would send it back to Royal for analysis.
Old 07-22-2011, 10:31 PM   #5
Looks like that did the trick. After a few miles on the road we have smooth shifts now.
Old 07-22-2011, 10:42 PM   #6
Quote:
I ran RP gear oil for a while in the tC. Shifting started to suck so I switched it out to the Eneos gear oil. Love the stuff, I just did my second drain and fill on it.
amp0804 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
HELP! Selling STOCK 2007 tC as a 'fixer upper' and wondering if/what repairs to make mischadoll Maintenance & Car Care 3 03-09-2015 06:48 AM
Theory on TC and poor gas mileage evolving_machine Scion tC 2G Owners Lounge 14 03-05-2015 03:49 PM
The car is a compromise. evolving_machine Introduction Forum 6 01-13-2015 09:04 PM
tC2: PWJDM Balanced Shift Knob - GOLD FS pro710 PPC: Interior / Electronics 1 12-29-2014 07:52 PM
Where is tranny drain plug? ghasper Maintenance & Car Care 8 02-22-2006 01:18 AM
Tags
2006, change, check, fluid, gear, manual, oil, scion, spec, standard, tc, transmission, xa, xb, xd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
