Engine stuttering
Old 04-27-2023, 07:35 AM
JayB's Avatar
Default Engine stuttering
Took my 04 xb out for a quick trip to the corner store, on the way hone she started sputtering and seemed to have real lack of power. no engine codes. Located here in Medford Oregon.
JayB is offline
Old 04-27-2023, 12:40 PM
armygreenxb's Avatar
How's the car been maintained and how many miles? Lots of things to check - fuel filter, air filter, MAF sensor, throttle body.
armygreenxb is offline
Old 04-27-2023, 01:26 PM
LULU's Avatar
Probably need more information and details about the car. Auto/Man? Smoke or anything leaking?
LULU is offline
Old 05-04-2023, 10:53 PM
okokray's Avatar
max air flow sensor ??
okokray is offline
Old 05-06-2023, 03:34 AM
sh0rtlife's Avatar
a sudden stutter and no codes really only points at 2 things air or fuel, specificly, did something "move in" to your air box, and have you recently been running the tank low?...running a fuel tank to neer empty will cause all the crap in the tank to get sucked into the filter, but it also causes the fuel pump to run hot, and can cause low pressure
thats my 2 cents without any extra info
sh0rtlife is offline
Old 05-07-2023, 08:57 PM
Moderator
Moderator
DannoXYZ's Avatar
vacuum leak. Sucking in extra air that's bypassing MAF and not being measured.
Codes only pop up when something's failed and sending out-of-range signals. In this case, MAF is being tricked, but still sending out OK signals. Just doesn't match actual air-flow conditions
DannoXYZ is offline
Old 07-15-2023, 11:27 AM
EileenTucker's Avatar
Thanks for the advice, sir. I will keep it in my mind.
EileenTucker is offline
Old 08-08-2023, 12:03 PM
You made my day, your advice is helpful.
Spoiler
Shiroi
47
02-11-2015 11:06 PM
johnmk
9
10-14-2011 01:05 PM
Rocket
03-29-2006 01:03 AM
SciFly
12
08-25-2005 06:42 PM
woof
10
08-18-2004 11:12 PM
Quick Reply: Engine stuttering
