Scion xB Tune Up - Scionlife.com
Reply
Thread Tools Search this Thread
Old 10-29-2008, 01:57 PM   #1
TypeX's Avatar
Default Scion xB Tune Up
Well winter is coming ... and i'm closing in on my first full year with my 05 box.
Last winter it didnt get that much use if anything but this year i'm at about 45,000 miles
( got it with 32,000 in oct 07) and i'm going to be doing all the maint
So anyone have a list of all the tuneup items or little tricks for the car?
...Maybe even some cheap sites to pick up all the goods
Plan is
oil change
trans flush
new brake rotors & pads
engine tune up plugs/cap/filters etc
Any help would be greatly appreciated
I'm a former honda guy and my scion xB knowledge is still in the noob category
i'm learning though ;)
TypeX is offline   Reply With Quote
Old 10-29-2008, 02:58 PM   #2
Moderator
Moderator
vettereddie's Avatar
Are you looking for OEM or aftermarket?
For oil filters, http://www.trdsparks.com sells 10-packs of the Toyota filter for $35, it's one of the best for our xB's. Don't bother with the TRD filter, just the regular black Toyota one. Same for coolant if needed, though the Toyota long life is 90,000 miles I think so you should be good other than topping off. For oil, switch to synthetic. I'm currently using Mobil1 but have heard Penzoil is the best for our cars. Use 5W30.
Trans. shouldn't need a flush unless you were towing, loading the box down a lot or it's shifting rough. if you do decide to do it, professional flushes can be $$ because they cycle through 4-5 times the ammount of fluid the trans actually holds, but gets it clean. Toyota uses a synthetic type T-IV. For aftermarket, Amsoil universal ATF says it meets the Toyota spec, as does Redline Synthetic D4 ATF and Synthetic High-Temp ATF, don't use any other Redline ATF.
Brakes and pads, I usually go to autozone and buy the generic Duralast gold pads and Duralast rotors. it isn't worth it to get the rotors balanced, new front rotors are $54. Drums I no longer touch, but they should last a bit longer than the front pads.
For engine tune, NGK copper plugs work fine, or get the platinum if you want to change them less often. You won't get a performance increase with them though. For air filters, I think K&N makes one, as does TRD that fits the stock airbox. The xB doesn't come with a cabin air filter, you can make one by buying one of the trim to fit ones from Walmart and put it in the tray behind the glovebox.
that's pretty much it other than checking the tires and other fluid levels (brake, power steering, washer) and maybe throw on a battery charger.
vettereddie is offline   Reply With Quote
Old 11-06-2008, 09:07 AM   #3
^^^^ great write up ...i need a tune up also...
jc21 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
?'s about e85 jdstC1 Scion tC 1G Owners Lounge 2 01-13-2015 05:45 AM
tC: Supercharged 06 tc auto 77k lots of aftermarket parts!! TheTripleC PPC: Vehicles 1 01-04-2015 07:46 PM
tC: PTUNING: Scion tC (2005-2010) Competition 3" Polished CAT-BACK Exhaust PTUNING PPC: Engine / Drivetrain 3 12-11-2014 09:09 PM
PTUNING: Scion tC (2005-2010) Competition 3" Polished CAT-BACK Exhaust PTUNING Exclusive Sponsored Sales 0 12-06-2014 04:58 PM
2006 Scion XA Catalytic Converter P0420 Code - What to do? rcflyer15 Maintenance & Car Care 3 12-05-2014 06:15 PM
Tags
06, brake, duralast, front, needed, pads, rotor, scion, stock, tc, tune, tuned, tuning, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
