XA Air Conditioner won't turn off - Scionlife.com
Reply
Thread Tools Search this Thread
Old 08-26-2010, 10:26 PM   #1
Default XA Air Conditioner won't turn off
I have an 05 XA. When I turn on the air but not the A/C button, I still get ice cold air, indicating the compressor clutch is engaged. It's a pain when I just want fresh air, but I'm wondering if the clutch is engaged when I am running the heater as well. The light on the A/C button does turn on & off.
Thanks for any comments...
DenverXA is offline   Reply With Quote
Old 08-26-2010, 10:28 PM   #2
Jan06xB's Avatar
Make sure you don't have it on defrost!
Jan06xB is offline   Reply With Quote
Old 08-26-2010, 10:34 PM   #3
By defrost, do you mean where the air is being blown out (ie. under the windshield for defrost)? I have the air blowing straight out the grills toward the driver/ passenger...
Old 08-26-2010, 10:37 PM   #4
RedneckwithanxB's Avatar
even if the AC button is turned off, you have to adjust the air temperature...
RedneckwithanxB is offline   Reply With Quote
Old 08-26-2010, 11:02 PM   #5
Quote:
If the A/C button is off, shouldn't the air coming in (w/ the temp dial turned all the way to its coldest) be the same temperature as the outside air? Currently, w/ the A/C button off, it is blowing air 10-20 degrees cooler than the outside temp...
Old 08-26-2010, 11:03 PM   #6
Jan06xB's Avatar
Quote:
Yeah that's what I mean . . . so if you just have it blowing from the front vents and not the top vents on the windshield then I would guess you have a stuck compressor clutch or a blown relay or transistor that turns the clutch on. There should be a wire that powers the clutch which you could disconnect. The real test is if it puts out really cold air with the fan turned off while you are moving. If the clutch is stuck on all the times then you will burn out the compressor pretty quick since it normally is not on all the time . . . watch the high rpms of the engine or you could really do some damage to the compressor until you get it checked. Remember that it is running on the same belt as the water pump and aternator so if the compressor locks up you are going to loose the belt and engine cooling.
Old 08-27-2010, 03:35 AM   #7
Quote:
Your first question was right on...
I've been driving all summer w/ the fan on defrost. What threw me a curve is that the front vents are still blowing at this setting (along w/ the windshield vents). Also, I didn't know that the A/C would turn on in defrost mode.
I turned the fan to front vents, A/C button off & had only outside air (temp) blow in. Seems like all is well (?), I just didn't know the scion system (1st year w/ the car). I've owned a lot of toyotas...
Thanks for your help & please respond if something doesn't seem right w/ my conclusion!
Old 08-27-2010, 11:18 PM   #8
Jan06xB's Avatar
YUP the vents on the side are for the side windows and the front vents center will also put out some air if you don't crank the dial all the way over as will the floor vents when on defrost. Glad we got that little problem figured out - they do that to dry out the air and clear the fog on the inside of the windshield - it clears in a few seconds on a rainy or cold day.
Old 08-28-2010, 09:55 PM   #9
VIP_CAMO's Avatar
I think in the manual it shows you that when you put that **** to defrost as stated it will turn the ac on.So as he stated put it to anything but that ans see what happens.,then turn it to to def and see if it kicks in or if the rpms change.
VIP_CAMO is offline   Reply With Quote
Old 08-29-2010, 04:22 AM   #10
Jan,
Thanks for your help. I see your URL is GasSavers.org. Should I be happy w/ the 31 mpg, mostly city, I'm getting w/ my XA?
Ralph
Old 08-29-2010, 06:55 AM   #11
Admin
burstaneurysm's Avatar
^ 31 seems to be about right for an xA. Glad you figured out the defroster issue.
burstaneurysm is offline   Reply With Quote
Old 08-30-2010, 02:39 PM   #12
Jan06xB's Avatar
Jan,
Ralph
Well I left Logan airport at about 2pm one day and drove around Boston for about 2 hours averaging 40mpg in my xB 2006 so . . . . you could do better. I get really low fuel burn rates at idle like 0.12gph which is why my city driving mpg is so high.
Reply
Thread Thread Starter Forum Replies Last Post
Scion Navigation System setpol Scion tC 1G Owners Lounge 0 02-17-2015 11:33 PM
xB: 2006 Scion xb for sale 5 speed toyotaisme PPC: Vehicles 0 01-10-2015 10:24 PM
Sputtering/ backfire at idle/ low RPM now won't start cid_mcdp Maintenance & Car Care 4 01-05-2015 02:45 PM
2005 XB Loss of Power ScionRo Maintenance & Car Care 1 01-02-2015 07:54 PM
08 XD Fuel Pump replacement dgm458 Scion xD Drivetrain & Power 1 12-07-2014 05:59 PM
Tags
ac, air, clutch, conditioner, defrost, disconnect, fan, knob, light, relay, scion, toyota, turn, wont, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
