DIY-Crankshaft Position Sensor
Old 01-24-2018, 04:00 PM
Esbe's Avatar
Default DIY-Crankshaft Position Sensor
I consolidated my experience changing a CPS on a 2004 xB 1.5l 1NZ-FE:
Esbe is offline
Old 01-27-2018, 11:26 PM
Administrator
Administrator
MR_LUV's Avatar
Thumbs up
Excellent DIY! Wonderful Illustrations!
Becomes a Sticky
MR_LUV is offline
Old 09-09-2018, 09:07 PM
caliscion83's Avatar
Why did you replace your sensor? Mine is all gunked up with oil and I have P0012 error.
https://i.imgur.com/pt6KAsV.jpg
https://i.imgur.com/qvMuWLV.jpg (upside down close up)
___
caliscion83 is offline
Old 09-09-2018, 11:45 PM
Also do you have to drain the oil before replacing?
Old 09-10-2018, 02:46 AM
Here is the part in question. I cleaned it off a bit and got a better picture. Is that the crankshaft position sensor. The harness also doesn't look that good.
Old 09-10-2018, 01:42 PM
Esbe's Avatar
Default from Esbe
You are correct that that is the crankshaft Position Sensor. You do not have to drain the oil to replace this.
I did not have a code but I bought the vehicle used with 130K and did not know how hard that little motor was made to work. I did preventative maintenance and among other parts I changed this and the VVT solenoid which could be your code source. The VVT solenoid will cost about $60 at this time, no need to change the oil, and is super easy to change.
-- Reactor - Senior Member says "P0012 means: Camshaft Position "A" - Timing Over-Retarded. This code is not an indication of a bad camshaft position sensor. For that we have P0340"
-- Here's your P0012 code explained and it mentions the VVT (or VCT) solenoid (code P0010) as a probable cause:
https://www.yourmechanic.com/article...by-jay-safford
If you decide to change the VVT solenoid,
-- This guy does an excellent job of showing you how to change the VVT solenoid with lots of pictures:
http://www.clubxb.com/forums/scion-x...ml#post1127425
After you remove the plastic top engine cover, here's my note sheet:
Esbe is offline
Old 09-10-2018, 02:01 PM
Thanks a lot! I already did the OCV sensor swap so VVT and CPS will be next on my list.
Do you have part numbers available?
Old 09-10-2018, 02:21 PM
Esbe's Avatar
I'm sorry but the part costs twice what I mentioned previously. I'll edit the post.
Here's the part I installed a year ago and since then no issues with the part:
STANDARD MOTOR PRODUCTS VVT162 {#1533021010, 1533021011, 1533021020} (Standard Replacement
Here's where I got it from:
https://www.rockauto.com/en/parts/st...actuator,12910
here's a general description of that product:
http://eaccess.smpcorp.com/eCatalogs...16_JTF_VVT.pdf
Esbe is offline
Old 09-10-2018, 02:48 PM
No worries, I’ll probably pick it up on eBay which their sales lately I should get a good discount. Do you also have the crankshaft position sensor part # handy?
Old 09-10-2018, 03:41 PM
Esbe's Avatar
Default Crank Positoin Sensor Part #
Beck Arnley 180-0307 Crank Angle Sensor
I installed this a year ago and have had no issues with this part.
Let us know how it goes with your repair.
Esbe is offline
Old 09-10-2018, 03:55 PM
Esbe's Avatar
I was looking over the posts and if you replaced the OCV (oil control valve) you've replaced the VVT solenoid - same part different names.
In the second video at 4:20 take note of the mention of an 8mm hex bolt filter beneath the Oil Control ValveToyota 15678-21010 Oil Control Valve Filter
https://parts.toyota.com/a/Scion__XB...04.html#15678A
or
Amazon Amazon
Esbe is offline
Old 09-10-2018, 04:10 PM
This will be the worst case for the P0012 :
https://www.youtube.com/watch?v=vyp5_2i_3cA
https://www.youtube.com/watch?v=RrYbow6O9zI
Yes, I already changed that and cleaned the filter too. No go. I noticed the gunky crankshaft position sensor so I'll do that and see if that makes a difference.
Otherwise, I have a case open with Toyota about the P0012 but that would require me to go to the dealership for an inspection.
Thanks for sharing the part number. I ordered it already and will hopefully have it replaced later this week.
Do you know anything about the Crankshaft Position Sensor wiring? Should I replace that wire or just clean it off with some Simple Green?
____
Old 09-10-2018, 05:03 PM
Super Moderator
SuperMod
MileHightC's Avatar
Once again, excellent illustration and thanks for taking the time to do this.
MileHightC is offline
Old 09-10-2018, 11:56 PM
I'm not sure if it's the angle but the OEM crank angle sensor on my picture looks like its connected to a large nut. Did yours look like that?
Old 09-14-2018, 03:36 AM
Okay. The part posted a picture of was not the Crankshaft Position Sensor, and I still don't know what it is. However, I did replace my crankshaft position sensor since I was there. Good thing I did, here's what it looked like:
I cleaned up the other sensor from the outside. I couldn't even get the locking mechanism to budge because the wiring is so snug. I'm still trying to figure out what this is and if it's easily replaceable:
Old 01-12-2019, 02:14 AM
scwillbow's Avatar
Default Where is the crankshaft sensor on the Scion xB? I looked where the picture shows
Where is the crankshaft sensor located? I looked where the pic shows but doesn’t look like the replacement part
scwillbow is offline
Old 01-12-2019, 05:15 PM
Super Moderator
SuperMod
MileHightC's Avatar
Crankshaft position sensor is located exactly where it shows in the diagram at the top of this post. If your replacement part doesn't look like what is shown it may be the wrong part...do you happen to have a picture of your part or where you got it and a part number?
Looking at RockAuto all of the replacement sensors look like the ones shown above:
Old 04-22-2021, 03:29 PM
Birsan's Avatar
@MileHightC Hi, I got the Camshaft Position Sensor. I was removing the Air filter and the Battery (on Tuesday). I was looking on the engine driver side. Please let me know why there I can not find this part?
Thank you.
Looks like the best part for the job!!
I can not find where to install this in Scion xB 2004!!! Or to use on the key chain?
___
Birsan is offline
Old 04-25-2021, 01:59 PM
2stroked's Avatar
Thank you.
___
Exactly why are you replacing your CPS? Better yet, why are you replacing it with another junk Chinese made part? And I don't care if it says "OEM Quality" on the package because unless it's an OEM Toyota part, it doesn't meet their standards.
2stroked is offline
Old 03-14-2022, 01:28 PM
ApexMan's Avatar
Hi! Would there be a tutorial for crank sensor replacement for a 2015 xB? I'm stuck at removing the sensor cable behind the serpentine belt and alternator.
ApexMan is offline
caliscion83
09-09-2018 08:55 PM
zzbear
04-19-2015 06:18 PM
klick81
07-20-2011 08:54 AM
ecko04
08-02-2010 12:08 PM
thendawg
07-30-2008 04:36 PM
Quick Reply: DIY-Crankshaft Position Sensor
